Errors with thermophysicalProperties in rhoSimpleFoam
Old   November 11, 2013, 05:59
Default Errors with thermophysicalProperties in rhoSimpleFoam
aerogt3 is on a distinguished road
Hey all, I cannot get a single iteration to run in rhoSimpleFoam. I copied the boundary conditions and transportProperties from the tutorial below, but it still won't run!
/opt/OpenFOAM/OpenFOAM-2.2.x/tutorials/compressible/rhoSimpleFoam/angledDuctExplicitFixedCoeff
Here are the errors. Any ideas what it could be? I have tried changing BC's, changing transport models, etc. Nothing works! I am using the exact thermophysicalProperties file from the tutorial!
Reading thermophysical properties
Selecting thermodynamics package hePsiThermo<pureMixture<sutherland<hConst<perfectGas<specie>>,sensibleEnthalpy>>>
[3] #0  Foam::error::printStack(Foam::Ostream&)[9] #0  Foam::error::printStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process.  Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption.  The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
Local host:          dell-ws02.hwa.local (PID 10743)
MPI_COMM_WORLD rank: 7
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
[0] #0  Foam::error::printStack(Foam::Ostream&)[1] #0  Foam::error::printStack(Foam::Ostream&)[2] #0  Foam::error::printStack(Foam::Ostream&)[4] #0  Foam::error::printStack(Foam::Ostream&)[5] #0  Foam::error::printStack(Foam::Ostream&)[6] #0  Foam::error::printStack(Foam::Ostream&)[7] #0  Foam::error::printStack(Foam::Ostream&)[8] #0  Foam::error::printStack(Foam::Ostream&)[10] #0  Foam::error::printStack(Foam::Ostream&)[11] #0  Foam::error::printStack(Foam::Ostream&)[12] #0  Foam::error::printStack(Foam::Ostream&)[13] #0  Foam::error::printStack(Foam::Ostream&)[14] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[14] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[9] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[4] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[5] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[6] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[12] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[13] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2
[5] #2
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platform in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" in "/opt/OpenFOAM/OpenFOAM-2.2.x/platfos/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #2  rms/linux64GccDPOpt/lib/libOpenFOAM[4] #2
.so"
[6] #2
[3] #2
[8] #2
[10] #2
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM. in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[12] #2
[13] #2
[9] #2
[14] #2
[1] #2
so"
[0] #2
[2]  at sigaction.c:0
[2] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[6]  at sigaction.c:0
[6] #3  [4]  at sigaction.c:0
[7]  at sigaction.c:0
[7] #Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[5]  at sigaction.c:0
[5] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[4] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[3]  at sigaction.c:0
[3] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[1]  at sigaction.c:0
[1] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[8]  at sigaction.c:0
[8] #3  [10]  at sigaction.c:0
[10] #3  [14]  at sigaction.c:0
[14] #3  [12]  at sigaction.c:0
[12] #3  [13]  at sigaction.c:0
[13] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[0]  at sigaction.c:0
[0] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[9]  at sigaction.c:0
[9] #3  [11]  at sigaction.c:0
[11] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[2] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[6] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[4] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDP[7] #4  Opt/lib/libfluidThermophysicalModels.so"
[5] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&)Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[1] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[3] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[0] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/lin in "/opt/OpenFOAM/OpenFOAM-2.2.x/platf in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/li in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccD in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/ in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/ in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidTh in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[12] #4  ux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[8] #4  orms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[14] #4  nux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[10] #4  POpt/lib/libfluidThermophysicalModels.so"
[9] #4  libfluidThermophysicalModels.so"
[2] #5  libfluidThermophysicalModels.so"
[13] #4  ermophysicalModels.so"
My initial conditions are:
epsilon: 6.9 for epsilon on all walls and freestream, compressible::epsilonWallFunction, fixed value inlet, zero grad outlet
k: same as above, but 0.015 as the value and compressible::kqRWallFunction
T: fixedValue at inlet, zeroGrad everywhere else.
Pressure:
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 101325;
boundaryField
 velocityinlet
    type totalPressure;
    gamma 1.4;
    p0 uniform 102856.25;
  pressureoutlet
    type fixedValue;
    value $internalField;
Velocity:
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
  velocityinlet
    type pressureInletVelocity;
    value uniform ( 0 0 0 );
  pressureoutlet
    type zeroGradient;
aerogt3 is offline   Reply With Quote
Old   November 14, 2013, 06:28
Interestingly, the case will run 1 iteration before blowing up when run in serial.....but I still have no idea why!
Reading field U
Creating turbulence model
Selecting RAS turbulence model realizableKE
realizableKECoeffs
Cmu             0.09;
A0              4;
C2              1.9;
sigmak          1;
sigmaEps        1.2;
Prt             1;
No finite volume options present
Starting time loop
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.00047227, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1.06996e-13, Final residual = 1.06996e-13, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 0.999834, Final residual = 0.00119021, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.29473e-05, Final residual = 1.06133e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00507569, No Iterations 2
time step continuity errors : sum local = 348.194, global = -177.004, cumulative = -177.004
rho max/min : 1.21956 1.20141
ExecutionTime = 2.44 s  ClockTime = 2 s
Time = 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.0123603, Final residual = 2.18858e-05, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0441758, Final residual = 0.000528528, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0365402, Final residual = 0.000264662, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1, Final residual = 0.000391816, No Iterations 1
at sigaction.c:0
#3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/rhoSimpleFoam"
#6  __libc_start_main in "/lib64/libc.so.6"
File cleanup
Old   November 30, 2013, 04:46
Srivathsan N
Sherlock_1812 is on a distinguished road
I am having a similar error. Have you found a solution to it yet?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   September 22, 2015, 09:40
Default Same error
nitw.deepak@gmail.com
DeepIndia is on a distinguished road
Reading field U
realizableKECoeffs
Cmu             0.09;
A0              4;
C2              1.9;
sigmak          1;
sigmaEps        1.2;
Prt             1;
Starting time loop
Time = 1
Time = 2
at sigaction.c:0
File cleanup
Hi Man,
Hoe did you find the soultion , i have the same error?
DeepIndia is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
