pisoFoam simulation problem
Old   September 9, 2015, 09:05
Default pisoFoam simulation problem
Subhasree
Subhasree is on a distinguished road
Hi everyone,
I am working on external laminar flow over model with a velocity of 10 m/s using pisoFoam>ras using snappyHexMesh. The mesh part has been done but I am unable to simulate the flow. On running pisoFoam solver, it is giving the following error:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
Starting time loop
Time = 0.005
Courant Number mean: 0.166758 max: 7.5028
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
Please suggest how should I proceed to rectify this error.
Thanks!
Subhasree is offline   Reply With Quote
Old   September 10, 2015, 07:52
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Can you post the boundary + initial conditions and the fvSolution file?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Problem in initializing transient simulation with a finer mesh sidd CFX 8 April 29, 2016 02:25
SimpleFoam convergence problem with really simple simulation mayank.dce2k7 OpenFOAM Running, Solving & CFD 2 November 19, 2013 05:28
Low pressure de Laval simulation convergence problem heksel8i FLUENT 3 July 22, 2013 10:28
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 21:01
Heat Transfer simulation: No convergence problem fiqs CFX 2 April 21, 2010 15:47
