2nd Order Convergence Problem for 3D Airfoil
Old   September 8, 2015, 08:16
Unhappy 2nd Order Convergence Problem for 3D Airfoil
Gokce Turkmen
turkmengokce is on a distinguished road
Hi everyone,
I am working on simulating flow over 3D airfoil. I solved my case in first order Simplefoam but now I want to solve it in second order. But I didnt verify my first order result, it seemed good to me.
I tried different schemes only one of it converged but the residuals were higher than my first order. I used my converged result from first order simplefoam as initial guess. I only changed divergent schemes in simplefoam to increase the order. I put them at the end of this thread. (only the last one worked)
I tried icofoam but courant number diverged after some time. My case is laminar. I used my converged result from first order simplefoam as initial guess. I would be very greatfull if someone help me to solve my problem, because I have been working on this for long time.
I tried the schemes below:
divSchemes
default none;
div(phi,U) Gauss linearUpwind grad(U);
div(phi,k) Gauss linear;
div(phi,epsilon) Gauss linear;
div(phi,R) Gauss linear;
div(R) Gauss linear;
div(phi,nuTilda) Gauss linear;
div((nuEff*dev(T(grad(U))))) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
,divSchemes
default none;
div(phi,U) Gauss SFCD;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear ;
div(phi,nuTilda) Gauss limitedLinear 1;
divSchemes
default none;
div(phi,U) Gauss QUICKV leastSquares;
div((nuEff*dev(T(grad(U))))) Gauss linear upwind;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV leastSquares;
I couldnt attach my case file so I am attaching my residualsi checkmesh results and BCs.
0/p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
airfoil
type zeroGradient;
sides
type freestreamPressure;
0/U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 0 0);
airfoil
type fixedValue;
sides
type freestream;
freestreamValue uniform (1 0 0);
Time = 0
Mesh stats
faces: 4159775
internal faces: 4037721
cells: 2049374
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 2049374
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
airfoil 72504 36528 ok (non-closed singly connected)
sides 2470 1393 ok (non-closed singly connected)
wall 47080 23974 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.85 -0.5 -1.66533e-16) (1.05 0.5 0.27)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.59378e-17 6.14025e-17 -3.65029e-15) OK.
Max cell openness = 3.74888e-16 OK.
Max aspect ratio = 6.7235 OK.
Minumum face area = 3.48265e-09. Maximum face area = 0.00154965. Face area magnitudes OK.
Min volume = 9.66928e-14. Max volume = 2.01324e-05. Total volume = 0.512781. Cell volumes OK.
Mesh non-orthogonality Max: 58.2936 average: 19.726
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.715771 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Thank you
turkmengokce is offline   Reply With Quote
Old   September 10, 2015, 07:20
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
1st order has more numerical dissipation than 2nd order, i.e. you spuriously solve for a case with artificially higher viscosity. Also, you damp all kinds of effects by 1st order schemes. Maybe your case just isn't stationary, which only appears in 2nd order?
Edit: Ok, you should post the whole schemes file and also the fvOptions. And some log output would be beneficial. Please use the "code" button (under "->Go Advanced') to post code - don't just copy it to the text box.
Also: Why do you specify all the different div-Schemes for a laminar case? This is pretty confusing.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
3d airfoil, icofoam problem, simplefoam second order
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
IS calc. with 2nd order discret. always necessary? Azman FLUENT 2 March 14, 2013 04:28
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 07:12
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
