[swak4Foam] Warning running groovyBC: "min ... max ... differ, I will use the average"
Like Tree2Likes
  • 1 Post By mick223
  • 1 Post By gschaider
Old   September 15, 2015, 22:39
Default Warning running groovyBC: "min ... max ... differ, I will use the average"
Mick McGill
mick223 is on a distinguished road
Hi everyone,
I'm running a case where heat loss is calculated through the walls using a groovyBC gradientExpression. The code used for this in 0/T is:
leftWall
        type            groovyBC;
        refValue        uniform 1680;
        refGradient     uniform 0;
        valueFraction   uniform 1;
        value           uniform 1680;
        valueExpression "0";
        gradientExpression "(Toutlet > 1680) ? ((-(h*A*(Toutlet-T_inf)+esp*A*sig*(pow(Toutlet,4)-pow(T_surr,4))))/kl) : ((-(h*A*(Toutlet-T_inf)+esp*A*sig*(pow(Toutlet,4)-pow(T_surr,4))))/ks) ";
        fractionExpression "0";
        evaluateDuringConstruction 0;
        variables
9
"h=10.0;"
"A=0.00845561879;"
"T_inf=297.0;"
"T_surr=297.0;"
"esp=0.3;"
"sig=5.67e-8;"
"ks=20;"
"kl=60;"
"Toutlet{leftWall}=oldTime(T);"
        timelines       (
        lookuptables    (
The case runs and the results are similar to what is expected, however the warning:
--> FOAM Warning :
    From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
    in file ExpressionResult/ExpressionResultI.H at line 350
    The minimum value 1674.98 and the maximum 1675.21 differ. I will use the average 1675.14
--> FOAM Warning :
    The minimum value 1682.8 and the maximum 1959.02 differ. I will use the average 1838.05
--> FOAM Warning :
    The minimum value 1682.8 and the maximum 1957.31 differ. I will use the average 1838.05
Any advice would be greatly appreciated. I have a feeling that it may be because of how Toutlet{backwall} is specified, it is looking to take data from another patch which would be required to be a uniform field, however I am not sure.
Thanks,
Mick.
mick223 is offline   Reply With Quote
Old   September 21, 2015, 10:52
Mick McGill
For anyone that comes accross this wanting to know what the warning was for, the use of the {} bracketed terms eg
Indicates to the solver that the boundary condition is being taken from a remote patch, which must have a uniform condition, hence the average temperature is taken. To have it instead calculate the boundary condition on a cell by cell basis, simple remove the {} term (in this case {leftWall} ).
wyldckat likes this.
Old   July 28, 2017, 12:21
Alejandro
ancolli is on a distinguished road
But, if u remove that term, how u get access to the remote patch?
ancolli is online now   Reply With Quote
Old   July 30, 2017, 08:55
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
General interpolation from one patch to another is tricky and would need additional specifications (especially if the patches are not conformal) so swak4Foam doesn't bother to even try and only accepts uniform patches. If the patches are coupled or mapped the functions neighbourField(T) or mapped(T) give the corresponding values. But oldTime won't work in these cases
the_ichthyologist likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   February 7, 2023, 08:48
Mohammad Reza
Bana is on a distinguished road
Too bad, I have been exactly looking for this application for groovyBC! Value on another patch for the oldTime()...
Seems there is no way other than doing it in C++
Bana is offline   Reply With Quote
groovybc, heat loss, warnings
Cavitation around NACA hydrofoil using interPhaseChangeFoam Kozan OpenFOAM Running, Solving & CFD 28 March 11, 2023 23:30
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 11:44
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 13:52
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Warning 097- AB Siemens 6 November 15, 2004 04:41
