First order in fvSchemes does not seem to work |
September 30, 2015, 20:06 |
Anonymous
Rep Power: 16 |
I'm completely new to OpenFoam and I got stuck with fvSchemes. I'm trying to run a rotational periodic case with SRFSimpleFoam. Because of bad convergence, I'd like to start with first order schemes However, I'm having problems with the scheme specs of "div((nuEff*dev(T(grad(Urel)))))" which only seems to work with Gauss linear; Furthermore I have problems running the laplacian schemes. I specified the fvSchemes file as: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default none; grad(p) Gauss linear; grad(Urel) Gauss linear; grad(omega) Gauss linear; grad(k) Gauss linear; } divSchemes { default none; div(phi,Urel) bounded Gauss upwind; // bounded Gauss linear; div(phi,k) bounded Gauss upwind; // bounded Gauss linear; div(phi,epsilon) bounded Gauss upwind; // bounded Gauss linear; div(phi,omega) bounded Gauss upwind; // bounded Gauss linear; div(phi,R) bounded Gauss upwind; // bounded Gauss linear; div(R) bounded Gauss upwind; // bounded Gauss linear; div(phi,nuTilda) bounded Gauss upwind; // bounded Gauss linear; div((nuEff*dev(T(grad(Urel))))) Gauss linear; // bounded Gauss upwind; did not work } laplacianSchemes { default none; laplacian(nuEff,Urel) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian((1|A(Urel)),p) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian(DkEff,k) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian(DepsilonEff,epsilon) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian(DomegaEff,omega) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian(DREff,R) Gauss linear corrected; //Gauss upwind uncorrected; did not work laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; //Gauss upwind uncorrected; did not work } interpolationSchemes { default linear; interpolate(Urel) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************************************* // Works fine, but div((nuEff*dev(T(grad(Urel))))) bounded Gauss upwind; Gives the error: Code:
[2] [2] [2] --> FOAM FATAL IO ERROR: [2] unknown div scheme bounded Valid div schemes are : 1(Gauss) [2] [2] file: IOstream.divSchemes.div((nuEff*dev(T(grad(Urel))))) at line 0. [2] [2] From function divScheme<Type>::New(const fvMesh&, Istream&) [2] in file /opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/divScheme.C at line 82. [2] FOAM parallel run exiting [2] Gives the error: Code:
[2] [2] [2] --> FOAM FATAL IO ERROR: [2] attempt to read beyond EOF [2] [2] file: IOstream.divSchemes.div((nuEff*dev(T(grad(Urel))))) at line 0. [2] [2] From function ITstream::read(token&) [2] in file db/IOstreams/Tstreams/ITstream.C at line 83. [2] FOAM parallel run exiting [2] Gives the error: Code:
[2] [2] [2] --> FOAM FATAL ERROR: [2] request for surfaceScalarField uncorrected from objectRegistry region0 failed available objects of type surfaceScalarField are 1(phi) [2] [2] From function objectRegistry::lookupObject<Type>(const word&) const [2] in file /opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line [0] 198 . [0] [2] [0] FOAM parallel run aborting --> FOAM FATAL ERROR: [2] [0] request for surfaceScalarField uncorrected from objectRegistry region0 failed available objects of type surfaceScalarField are 1(phi) [0] [0] From function objectRegistry::lookupObject<Type>(const word&) const [0] in file /opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198. [0] FOAM parallel run aborting [0] Anyone any idea? How do I set everything to first order to avoid bad convergence in the first iterations? Thanks in advance! |
fvschemes first order |
simpleFoam: switch so second order fvSchemes | okroud | OpenFOAM Running, Solving & CFD | 11 | September 11, 2013 12:52 |
First order simulation better than second order | Torque_Converter | CFX | 7 | January 8, 2013 04:07 |
How to compute UDS fourth order gradient | Emma66 | FLUENT | 1 | April 27, 2010 05:44 |
OpenFOAM - 2nd order of discretization? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 0 | November 12, 2009 07:15 |
Unstable flow simpleFoam 2nd order | Valle | OpenFOAM | 0 | August 26, 2009 08:12 |
