icoFoam error: "fileName::stripInvalid() called for invalid fileName"
Like Tree1Likes
  • 1 Post By comflics
Old   October 2, 2015, 01:17
Default icoFoam error: "fileName::stripInvalid() called for invalid fileName"
Michael.Mueller is on a distinguished road
Hello everybody,
I am new here. I want to run a simple icoFoam case but there is a error.
Can somebody tell me whats wrong?
Thank you very much!
Error:
| \\ / O peration | Version: 2.3.x |
| \\/ M anipulation | |
Build : 2.3.x-88ac82c68913
Exec : icoFoam
Date : Oct 02 2015
Time : 08:13:06
Host : "dem-EasyNote-TK81"
PID : 3170
Case : /home/dem/OpenFOAM/OpenFOAM-2.3.x/Pipe1/run/icoPipe1
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
fileName::stripInvalid() called for invalid fileName .~lock.ErrorMeldung.ods#
For debug level (= 2) > 1 this is considered fatal
Abgebrochen (Speicherabzug geschrieben)
Michael.Mueller is offline   Reply With Quote
Old   October 2, 2015, 04:05
Sadiq Huq
comflics is on a distinguished road
Originally Posted by Michael.Mueller View Post
Hello everybody,
Somewhere in your case directory there is a file with an invalid name. The file .~lock.ErrorMeldung.ods# looks like a temporary hidden file created by Libre Office. In your file browser, you can toggle Ctrl+H to see the hidden files. Or use the command
find . -print | grep lock
Ideally, your case directory should be located in $FOAM_RUN. Your directory Pipe1 should be inside run
BlnPhoenix likes this.
comflics is offline   Reply With Quote
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 34 December 8, 2022 21:27
[blockMesh] Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d tobimorak OpenFOAM Meshing & Mesh Conversion 5 October 4, 2016 14:07
Heat Transfer Error Message darsonli STAR-CCM+ 0 September 22, 2014 21:00
Error VolumeFractionLevel1 savr1484 STAR-CCM+ 3 February 4, 2014 00:55
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
