icoFoam error: "fileName::stripInvalid() called for invalid fileName" |
October 2, 2015, 01:17 |
Rep Power: 10 |
Hello everybody,
I am new here. I want to run a simple icoFoam case but there is a error. Can somebody tell me whats wrong? Thank you very much! Error: *---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.x-88ac82c68913 Exec : icoFoam Date : Oct 02 2015 Time : 08:13:06 Host : "dem-EasyNote-TK81" PID : 3170 Case : /home/dem/OpenFOAM/OpenFOAM-2.3.x/Pipe1/run/icoPipe1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time fileName::stripInvalid() called for invalid fileName .~lock.ErrorMeldung.ods# For debug level (= 2) > 1 this is considered fatal Abgebrochen (Speicherabzug geschrieben) |
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse | adona058 | OpenFOAM Bugs | 34 | December 8, 2022 21:27 |
[blockMesh] Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d | tobimorak | OpenFOAM Meshing & Mesh Conversion | 5 | October 4, 2016 14:07 |
Heat Transfer Error Message | darsonli | STAR-CCM+ | 0 | September 22, 2014 21:00 |
Error VolumeFractionLevel1 | savr1484 | STAR-CCM+ | 3 | February 4, 2014 00:55 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
