How to use movingWallVelocity B.C. with fixedValue? |
October 24, 2022, 11:48 |
Rention
Hello everyone,
I am trying to run a simulation of a moving mesh (solidBody motion). In my problem I need to implement boundary conditions at the outer boundary using an external lagrangian solver. this boundary has to move during the simulation. When I try to impose movingWallVelocity B.C. for the outer patch, the boundary conditions becomes noSlip even If I specify a different value, for example: Code:
outerBoundary { type movingWallVelocity; value uniform (3 0 0); } I also tried to define this boundary just with my calculated boundary conditions. But in this case the solver cannot understand that this patch as to move, and so it does not correct the fluxes giving an error in the continuity equation: Code:
Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Thank you in advance! |
moving 2d meshes, movingwallvelocity |
ACMI rotating zone: which frame is used for fixedValue, noSlip, movingWallVelocity? | zommuter | OpenFOAM Running, Solving & CFD | 0 | September 2, 2020 03:13 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 06:59 |
rotating wall inside of an MRF zone - fixedValue or movingWallvelocity? | evrikon | OpenFOAM Running, Solving & CFD | 3 | April 30, 2015 03:51 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
FOAM FATAL IO ERRORsimpleFoam | hariya03 | OpenFOAM Running, Solving & CFD | 6 | July 16, 2008 08:03 |
