A big issue in turbulence modeling
Old   August 24, 2018, 03:49
Default A big issue in turbulence modeling
Morteza
mortezahdr is on a distinguished road
Dear OF users,
I am using pimpleDyMFoam solver for turbulence modeling of fluid flow around a propeller. I am interested in near wall modeling, so on the propeller surface, y+<1 (~0.1). I use kOmegaSST turbulence model with omegaWallFunction, and fixedValue for k and nut on the propeller surface (~1e-8). The problem is that since the mesh has very small cells to resolve the boundary layer, the time step becomes very low, order of 1e-10. Therefore, it takes more than a month to get a converged solution and desired output. I know that by changing some settings in the fvSolution file, it is possible to increase the Courant number and fix the time step with a larger value, but this increase is not enough to get dt~1e-05. I would appreciate if users who have experience in turbulence modeling on dynamic mesh with y+~0.1 can share their experience with dealing the time step, Courant number and divergence issue.
Thanks.
mortezahdr is offline   Reply With Quote
Old   August 24, 2018, 05:38
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by mortezahdr View Post
Dear OF users,
Thanks.
Couple of things first: why such small y+ for RANS using wall functions? How is the approach for moving the propeller? Have you tested your grid with potentialFoam?
Santiago is offline   Reply With Quote
Old   August 24, 2018, 05:45
Morteza
1.After reading relative threads, I found that for near wall modeling, kOmegaSST may be used with no wall function for k and nut, but omegaWallFunction for omega. I do this to get rid of wall functions and do a near wall model. Is there any better turbulence model to do this?
2. Moving is done by using AMI patches, one for the statinary part of mesh and the other one for the rotating part, a cylinder around the propeller
3. I have not. What information can I get by doing so?
Thanks for your reply.
Old   August 24, 2018, 08:37
1. What do you mean by "near wall" model? All scales of turbulence are modelled in RANS, thus such refining near the wall seems to be counterproductive. Wall functions are needed anyway.
2. Good, how regular is the mesh in the interface region? Edge length ratio of the faces on the opposing sides?
3. Grid quality, mass conservation.
Old   August 24, 2018, 11:08
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I recommend another approach.
Simulate the global flow around the propeller with a normal sized mesh, which can be calculated in a few hours.
Use the results of this simulation as a boundary condition for the near wall computation. Probably, you may use a quasi 1d simulation for this. I write quasi 1d, because you need a 3d model for the turbulence happenings. But the model may be simply a cuboid. You don't need to solve all points at the propeller this way, only a cross section of different velocity at the boundary, calculated at the first step. It may even be, that you get a theoretical solution for this. Wall functions are nothing different but a theretical solution or at lest model for this region.
Most probably you have to make some more complicated models with more difficult geometry at some regions of interest.
Or short: Split the problem!
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 24, 2018, 13:56
Morteza
Dear Santiago,
Here is what potentialFoam gives, where the answer to your second question is included:
potentialFlow: Operating solver in PISO mode
Reading velocity field U
AMI: Creating addressing and weights between 2847 source faces and 2847 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1, 1
AMI: Patch target sum(weights) min/max/average = 1, 1, 1
Constructing pressure field p
Constructing velocity potential field Phi
No MRF models present
Calculating potential flow
GAMG: Solving for Phi, Initial residual = 1, Final residual = 0.00677908, No Iterations 8
GAMG: Solving for Phi, Initial residual = 0.141347, Final residual = 0.000454325, No Iterations 2
GAMG: Solving for Phi, Initial residual = 0.0231327, Final residual = 0.000150614, No Iterations 2
Continuity error = 0.133959
Interpolated velocity error = 3.36059e-06
Calculating approximate pressure field
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0065187, No Iterations 4
GAMG: Solving for p, Initial residual = 0.148052, Final residual = 0.00144734, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0302199, Final residual = 0.000234948, No Iterations 4
ExecutionTime = 171.14 s ClockTime = 172 s
End
When 30<y+<100 or above, you are in the log-layer and wall functions work. Wall functions estimate the boundary layer profile which it is not really the results provided by solver, but a rough estimation of what the results should be. On the other hand, when y+<5, the cell adjacent to the wall covers the viscous sub-layer and the results will not need any modification, they almost reflect the real values. In some marine applications, the error caused by y+>30 and wall functions will increase sharply. Therefore, to get most accurate results, I have generated a mesh with y+~1.
Old   August 24, 2018, 14:46
Morteza
I think it is a very good idea and will solve the problem, but is it possible to use the results of lets say mesh-A as initial values for mesh-B, while the two meshes are different?
Old   August 24, 2018, 16:26
Dear Santiago,
Some comments:
1. Conservation error is rather high, nevertheless not terribile. The problem may come from initial/Boundary conditions. If your objective is having a URANS solution, try using implicit time stepping along with a high courant (~2). Also, perform many outer iterations if using pimple. It may be good idea to start the solver with a potential field. It may also be important to calculate the mesh peclet, and courant number, based on the potential field and some reference time scale.
2. For k and omega, independent from grid refinement and y+, you need wall functions. Depending on the particular implementation such wall functions may or may not switch from self-similar solutions, to empirical functions fitting some prescribed profile (power law, log law). Menter's komega sst proposes a zero gradient for k and omega at the wall, where the value at the first off the wall centroid is calculated according some formulae.
One last thing: are the explanations given the product of some study you've done on the komega sst model implemented in OF? I also work on marine propellers, but have seen that accuracy on integral values (kt, kq) is more dependent on the y+ range along the blades and rudder, than the min/max y+
Old   August 24, 2018, 16:34
Morteza
Some comments:
Thanks for your comments.
There is not clear explanation provided by openfoam. My boundary/initial values for this simulation are based on experience of other people with the same y+ and solver shared in this forum. The y+ value I have considered is the average on the propeller surface and I believe the average should show a value which covers boundary layer successfully.
Old   August 25, 2018, 07:52
Considering the mean as a metric for assesing the regime in which the solution of the boundary layer lies seems, to say the best, faulty. The mean may fall in the buffer region, maybe leading to the wrong conclusion that you might need to refine/decimate the near-wall grid. Maybe the distribution you have is very flat, giving the false impression that your solution may fall into the "twighlight" zone and forcing you to, most likely, refine.
Commercial meshing packages (gridgen, CUBIT) allow for plotting the distribution of edge sizes on your mesh/regions of interest in an attempt to optimize things
Old   August 26, 2018, 03:49
piu58's Avatar
Uwe Pilz
Of course. You read the results and make some interpolation of boundary values. All in all, you may have to do some manual work (with the pocket calculator). But it is not a complicated task in closer sense.
Uwe Pilz
pimple, time-step, turbulence, yplus
Checking if Turbulence modeling is on/off Jack001 OpenFOAM Programming & Development 6 July 17, 2016 15:39
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 02:47
synthetic turbulence fluctuation in LES Modeling SEB12129 STAR-CCM+ 1 October 9, 2015 12:18
Boundary conditions for RAS turbulence modeling HerrSchein OpenFOAM Pre-Processing 0 August 4, 2015 09:25
CFD-Wiki Monthly Focus Area: Turbulence Modeling Jonas Larsson Main CFD Forum 0 May 6, 2006 19:08
