anyone know the difference between three heat transfer boundary condition |
November 6, 2017, 08:38 |
ff
Rep Power: 16 |
Does anyone know what is major difference between the following three heat transfer boundary conditions? externalWallHeatFluxTemperature compressible::turbulentTemperatureRadCoupledMixed compressible::turbulentTemperatureCoupledBaffleMix ed Is it possible to use externalWallHeatFluxTemperature in multi-region conjugate heat transfer at border between solid and fluid? Thanks very much. |
November 11, 2017, 15:49 |
Rep Power: 20 |
compressible::turbulentTemperatureRadCoupledMixed compressible::turbulentTemperatureCoupledBaffleMixed Code:
externalWallHeatFluxTemperature There are also fvOption conditions to couple regions via their volume and not their boundary. For example useful if you want to simulate a heat exchanger without meshing thousands of interlocking pipes. You could instead couple them via a porosity and a function object. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
