atmospheric boundary layer (ABL) - implementing wind direction
Old   November 4, 2015, 20:57
Default atmospheric boundary layer (ABL) - implementing wind direction
Robert Ong
rob3rt 0ng is on a distinguished road
Hi all,
I'm having a lot of convergence issues when running simpleFoam using the ABL conditions with the wind direction. I've got three different mesh resolutions, all run without the wind direction i.e. flowDirection (1 0 0): the two finer ones (46 and 30m cells) converged, while the coarser mesh (12m cells) didn't. However, when running with the wind direction, for example east north-easterly (60deg), the simulations blew up (using all the three mesh resolutions). I implemented the wind direction by setting the flowDirection to (cos theta, sin 180-theta, 0), and since for this case all the angles are in positive values, I didn't switch inlet surfaces (inlet->outlet, and vice versa).
Could anyone please advise on this? I'm sure this is something quite common, however, I can't seem to find the solution in this forum (maybe I miss or overlook something). Please let me know if you need some output files (e.g. checkMesh, log files, etc).
Kind regards,
Robert
rob3rt 0ng is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 2 August 6, 2015 11:05
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Modeling of boundary layer wind profile in CFX 5 Cuong NK CFX 7 April 26, 2012 08:23
