November 7, 2015, 14:01 |
MPI error with simpleFoam
P.A.
Rep Power: 17 |
i am trying to start a simpleFoam simulation with OpenFOAM 2.3.x with a 14 Million cells grid on 96 CPUs on a Linux cluster running CentOS 6.4. I get the following error(s): Code:
SIMPLE: no convergence criteria found. Calculations will run for 40000 steps. Starting time loop forces forces: Not including porosity effects --> FOAM Warning : From function tetIndices polyMeshTetDecomposition::triangleTetIndices(const polyMesh&, label, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 643 No base point for face 9127, 4(1430 3077 4521 3403), produces a valid tet decomposition. --> FOAM Warning : From function tetIndices polyMeshTetDecomposition::triangleTetIndices(const polyMesh&, label, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 643 No base point for face 10448, 5(3645 4427 3179 4128 2868), produces a valid tet decomposition. --> FOAM Warning : Then: Code:
fieldAverage fieldAverage1: Starting averaging at time 0 Time = 1 [95] #0 Foam::error::printStack(Foam::Ostream&)-------------------------------------------------------------------------- An MPI process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your MPI job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: ... Code:
in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [95] #1 Foam::sigFpe::sigHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [95] #2 [95] at sigaction.c:0 [95] #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [95] #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [95] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [95] #6 [95] in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" [95] #7 [95] in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" [95] #8 [95] in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" [95] #9 [95] in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" [95] #10 __libc_start_main in "/lib64/libc.so.6" [95] #11 [95] in "/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" [ofslave32:04863] *** Process received signal *** [ofslave32:04863] Signal: Floating point exception (8) [ofslave32:04863] Signal code: (-6) [ofslave32:04863] Failing at address: 0x1f4000012ff [ofslave32:04863] [ 0] /lib64/libc.so.6() [0x35fd632920] [ofslave32:04863] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x35fd6328a5] [ofslave32:04863] [ 2] /lib64/libc.so.6() [0x35fd632920] [ofslave32:04863] [ 3] /usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam19GaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x345) [0x7fe740acedb5] [ofslave32:04863] [ 4] /usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam19GaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x2d) [0x7fe740acf01d] [ofslave32:04863] [ 5] /usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x4f7) [0x7fe740ac8397] [ofslave32:04863] [ 6] simpleFoam() [0x43561a] [ofslave32:04863] [ 7] simpleFoam() [0x448d51] [ofslave32:04863] [ 8] simpleFoam() [0x44903e] [ofslave32:04863] [ 9] simpleFoam() [0x445481] [ofslave32:04863] [10] /lib64/libc.so.6(__libc_start_main+0xfd) [0x35fd61ecdd] [ofslave32:04863] [11] simpleFoam() [0x41b781] [ofslave32:04863] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 95 with PID 4863 on node ofslave32 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- Thank you! Cheers, Pascal. |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 06:53 |
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 16:34 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
