Victor Jakitsch
Rep Power: 0 ![]() |
I'm having problems with the BC's set up for the simulation of this weir using interFoam. What happens is that the water doesn't flow through the weir, it simply fills it up as if the outlet boundary was a wall, I've tried two BC's set ups but with no luck. Any advise is welcome. Please find attached the 0 and trysurface files of the geometry. Thank you. |
Matej Muller
Rep Power: 14 ![]() |
Hi!
Instead of Code:
type variableHeightFlowRateInletVelocity; value uniform ( 0 0 0); flowRate 0.01; alpha alpha.water; Code:
type flowRateInletVelocity; volumetricFlowRate 0.01; value (0 0 0); Regards, matej |
Setting BCs for Riverine Flows using Interfoam | kflora | OpenFOAM Running, Solving & CFD | 38 | July 27, 2022 06:51 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 02:47 |
interFoam inlet / outlet BCs | ThomasV | OpenFOAM Running, Solving & CFD | 0 | March 27, 2015 10:56 |
Struggling with BCs for 'simple' interFoam case | rassilon | OpenFOAM Running, Solving & CFD | 1 | May 15, 2009 10:16 |
