[Sponsors] | |||||
Thomas Vossel
Rep Power: 14 ![]() |
Hello!
Does anyone have a definitive guide for which boundary conditions to choose when simulating e.g. a flow in a pipe with interFoam? I'd be interested to see the BCs for the inlet and outlet patches for alpha, p_rgh and U for both a pressure driven flow (where U BCs use the respective pressures) and a velocity driven flow (where you define certain velocities on both ends)... My background is that I'm simulating a change of viscosity of the "water" phase depending on temperature and pretty much want to see a higher velocity in the part of the pipe with lower velocity and effectively a slowdown in velocities in areas with higher viscosity. Finding correct BCs is troubling me though. I usually get things working but certain aspects still seem to deliver wrong or strange results. In my case it's all about having a domain that's completely filled by air (alpha = 0) which then gets filled from one side with my liquid (alpha = 1)... While there exist some discussions about this topic (some of which are outdated now) I never really saw tangible solutions. So if you have working BCs for interFoam it'd be nice if you could share them... |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? | nikesh | FLUENT | 0 | January 30, 2015 00:32 |
| simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? | Zaphod'sSecondHead | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 06:17 |
| flow around a circular cylinder with velocity inlet and outflow outlet | shuoxue | OpenFOAM | 1 | March 3, 2014 11:42 |
| [swak4Foam] Trouble setting groovyBC interFoam Inlet BC | mgdenno | OpenFOAM Community Contributions | 4 | July 1, 2012 09:16 |
| Outlet boundary setup for interFoam | mittal | OpenFOAM Running, Solving & CFD | 2 | July 14, 2010 09:59 |
