February 15, 2019, 08:19 |
Running localEuler ddt on transient case
Rep Power: 10 |
Hey everyone,
I am running a LES combustion simulation with PaSR. First, I calculated a steady solution with localEuler as ddt scheme and k-omega-SST. Afterwards I switched to LES, changed the timestep size and let it run. I forgot to change localEuler to Euler. The results look really good. My question is: Does localEuler affect the solution in a transient case? Can I trust the solutions or do I have to run the calculation again with Euler ddt? Solver is reactingFoam on OF6. Thanks sufjanst |
February 15, 2019, 13:25 |
Rep Power: 14 |
Quoting from here :https://cfd.direct/openfoam/user-guide/v6-fvschemes/
"localEuler: pseudo transient for accelerating a solution to steady-state using local-time stepping; first order implicit." So if you want an unsteady simulation, you'll need to use a different scheme. Caelan |
February 15, 2019, 16:59 |
W. Schuyler Hinman
Rep Power: 13 |
Unfortunately, if you are using local time stepping your statistics will not be correct. If you had areas with relatively small velocity variations, they may appear nice, but the small finite changes in velocity will affect the time steps. In reality, your simulation will be giving LES statistics in some sort of pseudo-time domain.
Schuyler |
February 17, 2019, 20:05 |
MF
Rep Power: 7 |
I believe in localEuler the solution is advanced in time at each node by using the maximum 'local' timestep. The solution att ecah node may be even updated before computing all the other nodes. Any relationship with the physical transient is lost.
Mrfl |
February 18, 2019, 03:27 |
Rep Power: 10 |
I only need the time-averaged values so it should be fine I guess. Anyways, I will run it with Euler ddt scheme to be sure.
Thank you guys! |
Transient species transport case | Hong M.H | Main CFD Forum | 0 | February 25, 2018 03:44 |
Time-averaging of variables over different time periods for transient case | m.uzair | FLUENT | 4 | December 20, 2017 05:40 |
Transient case with no inlet region | Ancient_Nik | CFX | 11 | March 21, 2011 01:46 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Fluidisation transient case | Vikas Kumar | Main CFD Forum | 0 | April 24, 2003 03:29 |
