foam-extend-3.2 - Coupled Turbulence Models
Old   November 27, 2015, 02:55
Default foam-extend-3.2 - Coupled Turbulence Models
Philippose Rajan
philippose will become famous soon enough
Hello everybody :-)
Its been a long time indeed :-) But well... I am still around and still very much using OpenFOAM (foam-extend actually).
Just a few quick and short questions...
* Does anyone have experience with the coupled turbulence models available from foam-extend-3.2 onwards?
* Specifically, what do I need to be aware of when trying to use the coupled turbulence models along with pUCoupledFoam?
* Are there any limitations when running in parallel?
* Are there any special solver or fvSchemes settings I need to use in order
to get the system running?
The reason for my questions...: I have tried pUCoupledFoam, and it works quite well for laminar cases... however, I have not been able to get the coupledKOmegaSST turbulence model running successfully.
Wish you all a good Friday ahead :-)
Regards,
Philippose
philippose is offline   Reply With Quote
Multiphase Turbulence Models im_lenny OpenFOAM Running, Solving & CFD 8 January 31, 2019 10:37
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
