pressureGradientExplicitSource fvOptions - Problems on different meshes
Like Tree2Likes
  • 2 Post By hcl734
Old   December 3, 2015, 09:50
Default pressureGradientExplicitSource fvOptions - Problems on different meshes
hcl734 is on a distinguished road
Hi all,
I am simulating a 2D-rib with periodic boundary conditions where OUTLET data is mirrored to INLET.
To keep the mass flow constant I am using pressureGradientExplicitSource in the fvOptions dictionary.
momentumSource
type pressureGradientExplicitSource;
active on; //on/off switch
selectionMode all; //cellSet // points //cellZone
pressureGradientExplicitSourceCoeffs
fieldNames (U);
Ubar ( 1 0 0 );
gradPini gradPini [0 2 -2 0 0] 0; // initial pressure gradient
flowDir (1 0 0); // flow direction
So obviously I want to keep speed constant at 1m/s.
To look at avg(U) I select all cells of my geometry and use plotSelectionOverTime with only statistics chosen,
It works fine on a coarse mesh, consisting only of quadratic blocks (AR=1).
The velocity oscillates a little but becomes constant quickly at the desired value of 1.
But when I try to use a wall refined mesh
Velocity drops to 0.8 and remains there giving bad results for my simulation since I have to adjust a sink term for temperature according to mass flow (~velocity).
Does anybody has an idea what could cause this strange behaviour?
You can download my example calculation here:
https://owncloud.tu-berlin.de/public...f8946fcc142237
Every help is appreciated!
Luttappy and vs1 like this.
hcl734 is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
Problems in my first attempt with chtMultiRegionSimpleFoam zfaraday OpenFOAM Running, Solving & CFD 1 April 8, 2014 18:20
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 26, 2008 23:58
Some problems with Star CD Micha Siemens 0 August 6, 2003 13:55
Restarting for problems with moving meshes Maya Siemens 2 October 4, 2002 03:51
