September 27, 2019, 11:56 |
Error with parallel running olaFlow
shima
Rep Power: 8 |
Hi there,
I am simulating a model with olaFlow solver with LES turbulence model and snappyHexMesh for meshing. I am running in parallel and there is an error that I am getting: -------------------------------------------------------------------------- An MPI process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your MPI job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: Local host: zagros-1-59 (PID 122215) MPI_COMM_WORLD rank: 38 If you are *absolutely sure* that your application will successfully and correctly survive a call to fork(), you may disable this warning by setting the mpi_warn_on_fork MCA parameter to 0. -------------------------------------------------------------------------- -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 38 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. I would be appreciated for any hint or help. Best, Shima |
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel | sbence | OpenFOAM Installation | 10 | December 5, 2018 08:44 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
