January 11, 2016, 01:11 |
Error about correctPhi during compilation
Federica
Rep Power: 10 |
Hi everybody,
I'm trying to compile a new solver, but during the compilation I have this error: correctPhi.H:2:1: error: expected constructor, destructor, or type conversion before ‘(’ token ( ^ In file included from correctPhi.H:11:0, from myInterPhaseChangeFoam.C:41: /opt/OpenFOAM/OpenFOAM-3.0.0/src/finiteVolume/lnInclude/continuityErrs.H:32:1: error: expected unqualified-id before ‘{’ token { ^ What is wrong with my solver? The correctPhi.H file is this: CorrectPhi ( U, phi, p_rgh, dimensionedScalar("rAUf", dimTime/rho.dimensions(), 1), geometricZeroField(), pimple ); #include "continuityErrs.H" I am using OpenFoam 3.0.0 Thank you! |
January 26, 2017, 14:16 |
Linyan X
Rep Power: 10 |
Hi my friend,
Were you create your solver based on 'interFoam' solver? Is there anything updated for this system's complaint? I am also facing this problem. Regards, Linyan |
June 16, 2017, 06:27 |
#3 | |
Nguyen Duy Trong
Rep Power: 12 |
Have you solved your problem, could you please share with me the way to overcome it? Thanks in advance |
November 1, 2017, 18:55 |
Rep Power: 8 |
Hi
I faced the same error while trying to build a custom interFoam solver. What solved it was being more specific about the include CorrectPhi.H (Capital C) . So, at the includes before main I changed #include "CorrectPhi.H" with #include "cfdTools/general/CorrectPhi/CorrectPhi.H", and added -I$(LIB_SRC)/finiteVolume \ to my options file. We are not using the same version of OpenFOAM but I hope this helps. Last edited by Genji; November 2, 2017 at 11:04. |
November 27, 2017, 15:53 |
#5 | |
Nguyen Duy Trong
Rep Power: 12 |
It works well. Thank you very much for your suggestion. |
December 2, 2020, 07:03 |
#6 | |
Daniele
#include "CorrectPhi.H" with #include "path/where/CorrectPhi/is/effectively/located", (in my case /opt/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/CorrectPhi.H) Thank you very much! |
June 5, 2021, 16:03 |
Deshik
Rep Power: 4 |
Hi! I have tried all the suggestions you gave in this thread. Earlier I used to get errors, and when I followed all your suggestions, now I didn't get any. But when I run a test case I didn't get the results. (you can see in the image)
If anyone resolved this issue completely please help.. I have also attached the appropriate files.... Thanks in advance.. |
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit | Sargam05 | OpenFOAM Installation | 13 | March 22, 2014 05:21 |
[swak4Foam] swak4Foam compilation for OF-2.0.0 | camoesas | OpenFOAM Community Contributions | 19 | December 10, 2012 13:24 |
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) | floydfan | OpenFOAM Installation | 7 | December 20, 2011 05:56 |
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 | ftec | OpenFOAM Installation | 7 | February 23, 2011 06:07 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
