AMI Log-file output
Like Tree1Likes
  • 1 Post By fumiya
Old   January 15, 2016, 07:09
Default AMI Log-file output
hcl734 is on a distinguished road
Hi all,
I am using AMI boundary condition between a solid and fluid region.
What is the meaning of
AMI: Patch source sum(weights) min/max/average = 0, 1.414076, 0.9999949
AMI: Patch target sum(weights) min/max/average = 0, 1.182242, 0.992691
in the log-file?
Best
hcl734 is offline   Reply With Quote
Old   January 15, 2016, 09:35
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I did a very simple test before and compiled my findings in my slide (p. 84-)
http://www.slideshare.net/fumiyanoza...using-openfoam
Hope this helps,
Fumiya
hcl734 likes this.
[Personal]
fumiya is offline   Reply With Quote
Old   January 16, 2016, 07:55
Thank you!
So since 1 is the optimal value I think mine are quite o.k., aren't they?
Old   January 17, 2016, 01:28
fumiya's Avatar
Fumiya Nozaki
I think it depends on which cyclicAMI or cyclicACMI you use.
Minimum and maximum weights ideally should be 1 in the case of cyclicAMI.
(I can't understand why the maximum weight is greater than 1.)
You might want to read the release note if you use cyclicAMI (lowWeightCorrection option):
http://www.openfoam.org/version2.3.0/ami.php
Hope this helps,
Fumiya
[Personal]
Old   January 19, 2016, 02:58
I am using
type            mappedWall;
        nFaces          141075;
        startFace       5371729;
    sampleMode      nearestPatchFaceAMI;
        sampleRegion    [...];
        samplePatch     [...];
in chtMultiRegionSimpleFoam to couple a solid and fluid region thermally.
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
