Rep Power: 15 ![]() |
Hi All,
It's be 3+ years since I last posted here, a long break from looking at OF and now I'm working mostly on trying to remember how I used to do things, but I'm not sure this is one of those issues. Referring to the attached picture... This is from a simple wind tunnel model, You can see the forces in the X resolve to a basically steady condition but Y and most importantly Z keeps moving around. I don't believe the model can be that unstable. This is from the last time stamp in the SimpleFoamParallelLog file: smoothSolver: Solving for Ux, Initial residual = 0.000495791, Final residual = 2.66623e-005, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00722292, Final residual = 0.000460959, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00239546, Final residual = 0.000142308, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0561813, Final residual = 0.00251192, No Iterations 2 time step continuity errors : sum local = 4.60976e-006, global = -6.60764e-009, cumulative = -1.52998e-005 smoothSolver: Solving for omega, Initial residual = 8.3893e-005, Final residual = 6.61511e-006, No Iterations 3 smoothSolver: Solving for k, Initial residual = 0.00104573, Final residual = 5.31296e-005, No Iterations 3 ExecutionTime = 45348.4 s ClockTime = 45348 s Which to me looks like the forces have resolved ok, the check mesh passes ok also, so I'm not sure where to start to get a grip on this. Any ideas? I'm wondering if the settings on the solver for p might be where I need to research? I'm currently using the setting below a-la the motorbike tutorial: p { solver GAMG; tolerance 1e-7; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; |
Since the last post i've found the effect of relaxationfactors in fvsolution, running with:
relaxationFactors { fields { p 0.2; //0.3; } equations { U 0.3; //0.7; k 0.3; //0.7; omega 0.3; //0.7; } } As opposed to the commented values I'm getting the results below, which are a lot more stable, I suspect I've over done it though. I think probably need to run the thing again with twice the iterations to prove a smaller number of iterations needed to get a decent steady-ish value of Z. |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
perpendicular flow visualisation during postprocessing | esukex | STAR-CCM+ | 1 | September 15, 2014 05:55 |
transient, impregnating flow problem | fgommer | FLUENT | 0 | February 29, 2012 16:10 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
