March 4, 2016, 06:19 |
Volume Cells
Robert R.
Rep Power: 10 |
Dear Community,
this is my first thread and I'm still new with OpenFOAM. I'm working on multiphase solver wich is based on InterFoam with some enhancements. Right now I want to implement a porosity criteria funtion based on Darcys law into the code. For these computations I need a loop, which is checking, if the temperatur in each cell and the cells within ten times the diameter of that cell are in a critical stage of solidification (this value is given by a temperature range). My problem is, that I don't know how I can identify one cell and check if the temperatures of the surrounding cells are below the given temperature range. Finally I want to add their volumes to a new value. I hope you are able to understand the problem. I image that the needed code is quite simple and not a big problem Thank you! |
[ICEM] Problem with prism cells | sidharath | ANSYS Meshing & Geometry | 0 | September 1, 2015 07:09 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
