icoFoam + symGaussSeidelSmoother resulted in division by zero
Old   February 24, 2016, 11:08
Default icoFoam + symGaussSeidelSmoother resulted in division by zero
louisiana
sahar.haddadian1989 is on a distinguished road
hi, I am trying to import my mehs from Pointwise to openfoam. however when I am running it, I got this error. would you please help em with that? Thanks.
[shadda7@smic1 firstPointwise]$ icoFoam > log &
[1] 29755
[shadda7@smic1 firstPointwise]$ #0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
in "/usr/local/packages/openfoam/2.3.0/INTEL-140-MVAPICH2-2.0/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/bin/icoFoam"
#10 __libc_start_main in "/lib64/libc.so.6"
#11
sahar.haddadian1989 is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
icoFoam won't run while Paraview is running MikeHersee OpenFOAM Running, Solving & CFD 2 January 6, 2015 05:06
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
