buoyantBoussinesqSimpleFoam with fixed temperature |
March 22, 2016, 08:54 |
Ruggero Poletto
Rep Power: 12 |
I have this simple case (see attachments).
It represents a car park. There is an area of this car park where I simulate a simple fire event (I would like to use a source term for the temperature). In this set-up I imposed a 300K fixedValue temperature over the fire boundary. Well, the simulation seems to be quite unstable and the temperature actually goes down rather than going up ... any idea? I put some small preview of the settings: 0/T file Code:
boundaryField { floors { type zeroGradient; } fire { type fixedValue; value uniform 300; } ramps { type fixedValue; value uniform 288; } jetPush { type zeroGradient; } jetSunction { type zeroGradient; } walls { type zeroGradient; } } Code:
ddtSchemes { default steadyState; } divSchemes { default none; div(phi,U) bounded Gauss upwind grad(U); div(phi,nuTilda) bounded Gauss upwind grad(nuTilda); div((nuEff*dev2(T(grad(U))))) Gauss linear; div(phi,T) bounded Gauss upwind; } gradSchemes { default Gauss linear; } interpolationSchemes { default linear; } laplacianSchemes { default Gauss linear corrected; } snGradSchemes { default corrected; } wallDist { method meshWave; } |
unexpected constant Temperature on a clip surface | Sungki | OpenFOAM Running, Solving & CFD | 0 | August 4, 2015 04:50 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
Wall BC: fixed Temperature Distribution | camoesas | OpenFOAM Pre-Processing | 0 | February 6, 2012 05:19 |
No Slip Wall with Fixed Temperature Boundary Condition | Karkoura | CFX | 7 | March 10, 2011 17:23 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
