March 7, 2016, 05:10 |
What are controldict.foam files
Victor Koppejan
Rep Power: 10 |
Hi Everyone,
I'm using CFDEM software which is combination of LIGGGHTS and OpenFOAM. in the system folder I have a controldict AND a controldict.foam file. Does anyone know what the latter of the two is? The simulation still runs when I remove it so I guess it's not crucial. I've tried googling 'controldict.foam' and I see that it appears in other codes that use OpenFOAM as a CFD solver. Thanks in advance for your help. Regards, Victor |
March 7, 2016, 06:38 |
Rep Power: 18 |
It's not a file which is commonly in OpenFOAM. *.foam extension is usually only used with paraview, have you launched it there by mistake?
Also, if you post the content of the file we might be able to tell you more. |
March 8, 2016, 08:09 |
gereksiz
Rep Power: 11 |
Sometimes they use .foam extension as original version. As it is said, .foam isn't used in OpenFoam. Probably it is used for storing the original file or a different version of it.
problem compiling with header files | jreiter164 | Fluent UDF and Scheme Programming | 2 | August 14, 2015 17:31 |
attaching trn files | hossein_sml | CFX | 1 | August 5, 2015 19:17 |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
Problems with result files | Kasper | CFX | 5 | December 14, 2006 02:41 |
