Error using MRFInterFoam in alpha1 field
Old   March 6, 2016, 09:22
Default Error using MRFInterFoam in alpha1 field
Maral Mohajer
MaralMohajer is on a distinguished road
Hi
I'm trying to model sth which is really simple , just a box with back and front empty patch , using MRFInterFoam.
in case of alpha1 I receive this error:
size 3072 is not equal to the given value of 280
can someone from experienced people here help me with?
I'm new to OpenFoam and feel like needing some help.
Best Regards
Maral
MaralMohajer is offline   Reply With Quote
Old   March 6, 2016, 09:50
BlnPhoenix is on a distinguished road
this error usually occurs when u have changed the mesh and try to initialize the fields with SetFields. Solution is to delete the old alpha.water file and copy the file from 0.org folder. When u use SetFields command it will actually write the field values in this default alpha.water file with correct number of cells (3072 in your case).
Give it a try.
BlnPhoenix is offline   Reply With Quote
Old   March 11, 2016, 03:31
Maral Mohajer
Thank you very much, it worked !
Maral
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 11:54
Using sample to Inlet velocity field amanbearpig OpenFOAM Running, Solving & CFD 14 November 16, 2015 05:47
Problems creating a volScalarField with expressionField function-object zfaraday OpenFOAM Running, Solving & CFD 2 January 12, 2015 07:49
Demagnetization field jan0385 ANSYS 0 April 12, 2012 09:09
