April 22, 2016, 09:55 |
point flottant (core dumped)
Mehdi
Rep Power: 10 |
helo everyone i have the same probleme, i would like to simulate an airflow around an airfoil i used rhosimplefoam like a solver and when i'm compiling its apear this message:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-d8a290b55d28 Exec : rhoSimpleFoam Date : Apr 19 2016 Time : 15:10:30 Host : "mehdi-HP-250-G4-Notebook-PC" PID : 7408 Case : /home/mehdi/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/home/mehdi/OpenFOAM/OpenFOAM-3.0.1/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam:perator/(Foam::tmp<Foam::Field<double> > const&, Foam::tmp<Foam::Field<double> > const&) at ??:? #5 Foam::fluidThermo::nu(int) const at ??:? #6 Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::fluidThermo>::nu(int) const at ??:? #7 Foam::nutkWallFunctionFvPatchScalarField::calcNut( ) const at ??:? #8 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:? #9 Foam::fvPatchField<double>::evaluate(Foam::UPstrea m::commsTypes) at ??:? #10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:? #11 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:? #12 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::kEpsilon(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:? #13 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::adddictionaryConstructorToTable<Foam::RASMode ls ::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiff usivity<Foam::CompressibleTurbulenceModel<Foam::fl uidThermo> > > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #14 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #15 ? at ??:? #16 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #17 ? at ??:? Exception en point flottant (core dumped) mehdi@mehdi-HP-250-G4-Notebook-PC:~/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam$ if someone can help me please it's for my master project, thank you |
April 22, 2016, 18:18 |
Mehdi
Rep Power: 11 |
Dear Mehdi,
I guess your zero conditions 0/k or 0/epsilon are making floating point exception. make sure internalField of these two files are not equal to zero. Regards, Mehdi |
April 22, 2016, 20:03 |
Mehdi
Rep Power: 10 |
thank u for replying, my k and epsilon aren't 0 I did everything, no results. I guess that this solver rhosimplefoam are not for external fluid or there's a mesh errors because I don't have a checkmesh command I have OF 3.0.1
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
ERROR : Floating point exception (core dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 4 | November 14, 2013 06:03 |
Segmentation fault (core dumped) when changing pressure BC | jptorol | OpenFOAM Running, Solving & CFD | 0 | September 25, 2013 18:05 |
Floating point error (core dumped) | sihaqqi | OpenFOAM Post-Processing | 1 | April 17, 2013 06:57 |
Exception en point flottant | thomasse | OpenFOAM | 3 | August 9, 2011 00:50 |
