InterDyMFoam unstable. InterFoam fine.
Old   October 5, 2014, 11:29
Default InterDyMFoam unstable. InterFoam fine.
Denao is on a distinguished road
Hi all,
I was hoping for some pointers. I have a case where I am trying to do some resistance predictions of a ship hull. The case runs fine using interFoam and seems to produce reasonable results.
If i try and run the same case with interDyMFoam the solution very quickly blows up, with the pressure forces becoming massive and the time step reducing so far as to cause a floating point exception.
I have also tried achieving a steady state with interFoam before continuing the run with interDyMFoam, with the same results.
My dynamicMeshDict is below, please let me know if there are any other outputs that would be useful:
DynamicFvMesh       dynamicMotionSolverFvMesh;
motionSolverLibs    ("libsixDoFRigidBodyMotion.so");
solver              sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
    patches         (hull);
    innerDistance   0.3;
    outerDistance   1;
    centreOfMass    (3.97 0 0.65);
    mass            10900;
    momentOfInertia (40 921 921);
    rhoInf          1;
    report          on;
    accelerationRelaxation 0.9;
    value           uniform (0 0 0);
    constraints
        zAxis
            sixDoFRigidBodyMotionConstraint line;
            direction     (0 0 1);
        yPlane
            sixDoFRigidBodyMotionConstraint axis;
            axis          (0 1 0);
    restraints
        translationDamper
        translationDamper
            sixDoFRigidBodyMotionRestraint linearDamper;
            coeff         8596;
        rotationDamper
            sixDoFRigidBodyMotionRestraint sphericalAngularDamper;
            coeff         11586;
Denao is offline   Reply With Quote
Old   April 30, 2016, 18:53
anas
AnasCFD is on a distinguished road
I am facing the same problem with interFoam & interDyMFoam for a 2D case. Could you manage to solve your problem?.
Your feedback is highly appreciated.
AnasCFD is offline   Reply With Quote
Old   May 6, 2016, 08:13
Federica Biano
federicabi is on a distinguished road
Hello everybody,
I'm trying to simulate a similar case but I have convergence troubles also with interFoam in OF 3.0.1. I imported the mesh from Star CCM+ with ccm26ToFoam and checkMesh gave me one error about max skewness on 17 cells in a region out of my interest(my mesh has about 800000 cells) so I did not consider this error (should I?).
I also set up a k-eps turbulent model.
Once I run the case, it diverges after few time steps giving unreasonable forces. I can't keep the Co number under 1 even with adjustableTimeRun option and alpha.water under 1.
I attach my dictionaries.
I appreciate your precious help.
Federica
federicabi is offline   Reply With Quote
dynamic mesh, interdymfoam, interfoam, openfoam
Difference between results in interFoam and interDyMFoam erebus OpenFOAM Running, Solving & CFD 0 January 29, 2014 08:31
InterFoam vs InterDyMFoam Rose2011 OpenFOAM 4 March 6, 2013 10:56
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 13:21
divergence behaviour of interFoam solver for very fine mesh purushotam85 OpenFOAM Running, Solving & CFD 0 June 23, 2010 18:57
alpha or alpha1 in interFoam & interDyMFoam wavytracy OpenFOAM Bugs 3 September 10, 2009 02:51
