March 27, 2019, 19:25 |
Wall function values
Brett
Rep Power: 13 |
Hi Foamers,
I've been doing research on wall functions, which ones to use, which ones might suit me etc... I'm a bit stuck on what value I should be setting them at, for example: Bottom_Wall { type omegaWallFunction; value uniform 1; } But how do I get any guidance as to what the value uniform should be? why 1? why not 0.1, or 100? Any thoughts? |
March 28, 2019, 03:06 |
Robert
Rep Power: 12 |
I'm either using the field values or zero. Both give comparable results.
If you liked my answer to your question, please consider leaving a "Like" in return |
wall funtions openfoam |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
