Boundary conditions for methane leak into air simulation
Old   April 5, 2016, 15:28
Default Boundary conditions for methane leak into air simulation
Anon
RebelLion is on a distinguished road
I'm attempting to simulate methane leaks into air and am struggling to finalize my choice of boundary conditions. I keep having issues with methane being partially trapped by the intended atmospheric/open boundary.
I'm currently using the transient incompressible two fluid solver, twoLiquidMixingFoam. I'd like to have a floor at the bottom, the sides and top open to atmosphere and a pipe sticking into the domain on one side.
What BCs would you recommend for p_rgh, U, and alpha at the pipe walls, inlet patch, floor, and atmosphere patches?
Thanks in advance for your help
RebelLion is offline   Reply With Quote
Old   April 5, 2016, 21:40
Yan Wang
wayne14 is on a distinguished road
Hi, twoLiquidMixingFoam is for multiphase flow: 'Solver for mixing 2 incompressible fluids.' Are you sure it is suitable for simulating methane leaks into air?
Regards,
Yan
wayne14 is offline   Reply With Quote
Old   April 6, 2016, 11:58
Anon
Hi Yan,
Thanks for your post.
You are right that twoLiquidMixingFoam is not ideal. I think it should be a fair approximation, ignoring any effects due to compressibility and should serve our purpose. From what I understand, if I want a compressible solver I should go to reactingFoam and turn off the chemistry. For now I'm using methane/air values for viscosity and diffusion coeffs and it's giving reasonable results, until my methane plume hits the boundary.
My problem is that any backflows are not allowed to exit the domain, they instead only appear to loose the normal component of their momentum and then continue via their tangential component, trapped within the boundaries.
Any other thoughts on this one?
Thanks!
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Radiation interface hinca CFX 15 January 26, 2014 17:11
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 08:17
