Residuals in buoyantBoussinesqSimpleFoam
Old   January 28, 2013, 04:51
Default Residuals in buoyantBoussinesqSimpleFoam
Nico A. is on a distinguished road
Dear FOAMers,
I am simulating a (laminar) natural convection boundary layer in 2D with the above-named solver. So my domain has a uniformly heated wall at the left and atmospheric inlet and outlet conditions at the top, bottom and right respectivly. The domain is attached.
The case is already running with the following BCs for T, U, p_rgh:
0/T
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 288.15;
boundaryField
    heatedWall
        type            fixedValue;
        value           uniform 298.15;
    right
        type            inletOutlet;
        inletValue      uniform 288.15;
        value           uniform 288.15;
    frontAndBack
        type            empty;
    inlet
        type            inletOutlet;
    outlet
        type            zeroGradient;
0/U
dimensions      [ 0 1 -1 0 0 0 0 ];
internalField   uniform ( 0 0 0 );
boundaryField
    heatedWall
        type            fixedValue;
        value           uniform ( 0 0 0 );
    right
        type            pressureDirectedInletVelocity;
    value        uniform (0 0 0);
    inletDirection  uniform (-1 0 0);
    frontAndBack
        type            empty;
    inlet
        type            pressureInletOutletVelocity;
    outlet
        type            inletOutlet;
        inletValue      uniform ( 0 0 0 );
0/p_rgh
dimensions      [ 1 -1 -2 0 0 0 0 ];
internalField   uniform 0;
boundaryField
    heatedWall
        type            buoyantPressure;
    rho        rhok;
        value           uniform 0;
    right
        type            totalPressure;
        U               U;
        phi             phi;
        rho             rhok;
        psi             none;
        gamma           1.4;
        p0              uniform 0;
    frontAndBack
        type            empty;
    inlet
        type            totalPressure;
        U               U;
        phi             phi;
        rho             rhok;
        psi             none;
        gamma           1.4;
        p0              uniform 0;
    outlet
    rho        rhok;
        value           uniform 0;
For the temperature difference of 10K and other flow parameters, the Rayleigh number is Ra=10^6, so a laminar boundary layer will develop, as you can see in the attached pictures for the Uz and T distribution at the vertical wall. The results seem to be physically correct.
But when I look at the residuals, they are oscillating (see attached picture). Normally they should fall due to given tolerances/ convergence criterions of 10^-08. The results are nearly the same for upwind and linear div-schemes.
I appreciate any suggestion regarding this case.
Best regards,
Nico
Nico A. is offline   Reply With Quote
Old   April 1, 2016, 09:13
Default Residuals in BuoyantBoussinesqSimplefoam
narayana vekamulla
vnarayana is on a distinguished road
Dear Nico,
Good evening i am doing natural convection using buoyantBoussinesqSimplefoam , please tell me how to plot residuals(convergence history). for a particular point (x,y), how to find maximum velocity. i used pyFoamPlotWatcher.py it is not working ? how to use foamLog in buoyantBoussinesqSimpleFoam ?
Thank you
vnarayana is offline   Reply With Quote
Old   April 4, 2016, 03:47
Karl Lindqvist
karlli is on a distinguished road
Dear Nico,
Please post your fvSolution file, could it be that your solver tolerance is set at 1e-4 where you experience the noise?
Best Regards,
Karl
karlli is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
under-relaxation factors -> level of residuals Zigainer FLUENT 19 July 21, 2017 16:53
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 12:18
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
