GAMG with cyclic boundary in parallel = crash |
April 4, 2016, 08:05 |
Ruben Di Battista
Rep Power: 13 |
I'm trying to simulate a two-phase problem in a pipe using twoPhaseEulerFoam. I noticed that when I run the case in parallel and I have GAMG as solver for p_rgh the computation crashes at first iteration on p_rgh. Seems related to this (http://www.openfoam.org/mantisbt/view.php?id=1247), but I'm on OpenFOAM 3.0.1. Any of you had experience about that? There are additional things to setup in decomposeParDict? I tried to setup preservePatches for the cyclic patches but no luck since now. The serial simulation instead proceeds and gives reasonable results. Code:
(Courant Number mean: 0.278509 max: 0.299811 Max Ur Courant Number = 0.170775 deltaT = 0.000320513 Time = 0.0131983 PIMPLE: iteration 1 MULES: Solving for alpha.SLN2 MULES: Solving for alpha.SLN2 alpha.SLN2 volume fraction = 0.13 Min(alpha.SLN2) = 0.0625242 Max(alpha.SLN2) = 0.236231 Constructing momentum equations Pressure gradient source: uncorrected Ubar = 1.3, pressure gradient = 217.899 Pressure gradient source: uncorrected Ubar = 1.3, pressure gradient = 1280.75 min T.SLN2 63.1 min T.LN2 63.2 GAMG: Solving for p_rgh, Initial residual = 0.282455, Final residual = 5.98708e+40, No Iterations 500 Pressure gradient source: uncorrected Ubar = -5.01445e+35, pressure gradient = 2.45967e+41 Pressure gradient source: uncorrected Ubar = -2.08706e+35, pressure gradient = 7.42086e+41 PIMPLE: iteration 2 MULES: Solving for alpha.SLN2 MULES: Solving for alpha.SLN2 smoothSolver: Solving for alpha.SLN2, Initial residual = 2.96995e-17, Final residual = 6.90969e-18, No Iterations 1 alpha.SLN2 volume fraction = 1.02942e+45 Min(alpha.SLN2) = -7.5363e+59 Max(alpha.SLN2) = 4.85275e+59 Constructing momentum equations Pressure gradient source: uncorrected Ubar = 2.34146e+22, pressure gradient = -6.61316e+84 Pressure gradient source: uncorrected Ubar = 4.48319e+21, pressure gradient = -6.54619e+84) |
April 4, 2016, 11:25 |
Mahdi Hosseinali
Rep Power: 18 |
I'm having similar issue too. I'm running channel359 case with dynamicLagranian model, it runs well when I'm using 4 nodes, and crashes on 8 nodes. However it runs for a considerable number of time steps before it crashes. It just happened recently so I didn't know where it's coming from but now that I checked I have similar settings for pressure solving method.
I suspect it could be a result of domain decomposition as it is sensitive to number of nodes. I have used the scotch method. Is this the same method you are using too? PS: running on OF3.0.1 too. |
April 5, 2016, 05:19 |
#3 | |
Ruben Di Battista
Rep Power: 13 |
For the moment I solved the problem changing the solver for pressure: Code:
p_rgh { solver PCG; preconditioner DIC; tolerance 1e-6; relTol 0; minIter 1; } |
April 5, 2016, 10:34 |
Mahdi Hosseinali
Rep Power: 18 |
results of solution in serial and with 2 and 4 nodes converge to a reasonable solution. But using 6 and 8 nodes one of the variables diverges in one step, so I assume it should be the domain decomposition that triggers the problem.
Thanks for sharing the solver method. I'll use it and will see how it goes. |
cyclic boundaries, gamg scaling multigrid, twophaseeulerfoam |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Problem with complex eigenValues | Harak | OpenFOAM Running, Solving & CFD | 11 | January 26, 2016 01:48 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 10:14 |
pisoFoam - unstable pressure residual | Industrial_CFD | OpenFOAM Running, Solving & CFD | 21 | February 24, 2013 15:39 |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 02:09 |
