SprayFoam: incorrect mass in system as mesh is refined
Old   April 6, 2016, 10:40
Default SprayFoam: incorrect mass in system as mesh is refined
Olabanji
banji is on a distinguished road
Hi Foamers,
I am using SprayFoam from OpenFOAM-2.3.x. I tried running a non-reacting case of n-dodecane injected into the domain using the default mesh in aachenbomb tutorial. All went well and no loss in mass.
To conduct a refinement study, I tried refining the mesh (as usual). To my surprise, I observed the total mass in the system by the end of injection is not even up to half of what was specied in "sprayCloudProperties" file i.e. massTotal.
I have tried the following:
Increased parcelsPerSecond from 2000000 to 16000000
Reduced minParticleMass to 1e-21
Reduced parcelsPerSecond from 2000000 to 200000
All to no avail. Any help would be appreciated.
Regards.
banji is offline   Reply With Quote
minparticlemass, parcelspersecond, sprayfoam
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
