Understanding openfoam residual discontinuities
Old   April 8, 2016, 05:44
Default Understanding openfoam residual discontinuities
Johannes Rasmussen
johannes.tophoj is on a distinguished road
Hi
On the attached image the residuals of my flow variables are shown as a function of the iteration count. The convergence criterion is 1e-5 for all variables but p, for which it is 1e-6. The residuals of the variables are discontinuous/make jumps, but perhaps it could be interpreted like some truncation as the shape of the curves before and after the jumps seem to match.
I'm merely curious. Can anyone explain these jumps?
Johannes
johannes.tophoj is offline   Reply With Quote
Old   April 16, 2016, 12:14
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which solver are you using?
  2. What relaxation values are you using?
Old   April 21, 2016, 03:08
Johannes Rasmussen
Hi
The solver is simpleFoam (consistent yes/true) with relaxation factor 0.3 on all variables. I have seen these jumps in several similar cases and as this case eventually converged (at iteration ~2600) my interpretation has been that it is some kind of numerical artefact and not a sign of convergence problems. But it did make me wonder...
Johannes
Old   April 21, 2016, 17:44
Bruno Santos
Hi Johannes,
I recently had a similar problem when using k-omega SST and it was related to two problems:
  1. I was running in parallel, for which k-omega is apparently more sensitive to the values defined in the boundaries named "processor".
  2. Turbulence fields should not be overly solved in the matrix equations.
    • In other words, if you have a very small tolerance in the entries for k/epsilon/omega in "fvSolutions.solvers", it can result in these situations you observed or it could potentially crash as well, because it diverged, given that the solution was incompatible with the other equations.
Best regards,
Bruno
Old   April 25, 2016, 08:51
Johannes Rasmussen
Hi again
Yes my jobs are parallel as well though I so far have not had any crashes. But thank you for the explanation
Johannes
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 21:33
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
