How to configure a job script? Example for another app available as a basis
Like Tree4Likes
  • 3 Post By wyldckat
  • 1 Post By arsalan.dryi
Old   April 14, 2016, 18:06
Default How to configure a job script? Example for another app available as a basis
Arsalan
arsalan.dryi is on a distinguished road
Hi Bruno,
After all of this, I got compiled OpenFOAM 2.3.0 and swak4foam 0.3.2 in my home folder at the cluster with your huge help and your support is greatly appreciated.
Well, for running my simulations I have to submit a script to the working directory of the cluster,not in my home folder. I don't know that the openFOAM works well by changing the directory or not. By the way, as you now an alias command do not work in a shell script, so I can't run "of230" in my job script in the working directory.
Do you have any ideas to fix this problem?!
A template of the job script is shown below for fluent simulations, and I am a bit confused with changing this template to that I need for a foam job!
#!/bin/bash
#PBS -N FLUENT
#PBS -j oe
#PBS -l nodes=1:ppn=2
#PBS -l walltime=00:30:00
module add ansys/v150 > /dev/null 2>&1
if [ $? -ne 0 ]; then
        echo "unable to load module files"
        exit 1
fi
cd $PBS_O_WORKDIR
fluent 3d -g -i input > fluent.log 2>&1
And an awkward question, should I use a parallel run in the cluster or the serial one would be enough?! Because I think that the parallel computing is complicated especially in a cluster, isn't it?
Thank you so much again for your time and attention.
Best Regards,
Arsalan.
[ Moderator note: Moved from here: http://www.cfd-online.com/Forums/ope...ot-access.html ]
arsalan.dryi is offline   Reply With Quote
Old   April 15, 2016, 19:21
Retired Super Moderator
Bruno Santos
Hi Arsalan,
I've moved your post from the other thread to a new one, because this is a new topic and it's related to "running", not "installing"
Using your example as a basis, the following should do the trick:
#!/bin/bash
#PBS -N OpenFOAM
#PBS -j oe
module add mpi/openmpi/gcc/1.8 > /dev/null 2>&1
        exit 1
fi
#Load up OpenFOAM's environment
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI
cd $PBS_O_WORKDIR
mpirun -np 2 simpleFoam -parallel > log.simpleFoam 2>&1
This should run simpleFoam in parallel with 2 cores.
If you're using a cluster, then you should run in parallel
Nonetheless, keep in mind that not all of OpenFOAM's applications can run in parallel, e.g. blockMesh.
Best regards,
Bruno
arvindpj, arsalan.dryi and alia like this.
Old   April 25, 2016, 15:01
Arsalan
Hi Bruno,
Your modified script worked properly as expected and finally, I could run my simulations in the cluster.
At this time,I'm studying the effect of the number of processors in CPU time of the parallel running.
I'm grateful to you for your help and attention.
King regards,
Arsalan.
wyldckat likes this.
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 12:36
SGE fluent job submission script mrji8011 FLUENT 2 May 5, 2011 20:59
running OF on local machine with batch script / job scheduler val46 OpenFOAM 13 November 10, 2010 03:22
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
cfd job Dr. Don I anyanwu Main CFD Forum 20 May 17, 1999 15:13
