How to set fully developed flow aty inlet?
Like Tree1Likes
  • 1 Post By nimasam
Old   September 25, 2015, 15:59
Default How to set fully developed flow aty inlet?
Fernando Soares Alves
FernandoSoares is on a distinguished road
Hi there Foamers,
I was wondering how to set properly a fully developed velocity profile WITH the pressure gradient required to push the fluid (newtonian). As far as I have checked mostly what has been adopted regards only mapping the velocity profile at the geometry inlet however with zeroGradient for the pressure field.
Is it just me or does these b.c. sound quiet off? Suppose I do know the pressure gradient in order to assure the development of the flow, which b.c. should I adopt at the outlet? I mean for a simple geometry, e.g. a backward facing step for instance.
I was trying something like
U:
    inlet
        type            fixedValue;
        value           nonuniform List<vector>
     (developed velocity profile here ...)
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
p:
    inlet
        type            fixedGradient;
        gradient        uniform (~known Pressure Gradient);
    outlet
        type            outletInlet;
        outletValue     uniform 0;
        value           uniform 0;
and I get no good convergence whatsover. (FYI I start the run with a mapped solution obtained from a previous result for a smaller geomtery). A plot of the residuals I am getting for simpleFoam with standard kEpsilon model is attached to this thread.
How is one suppose to set such a boundary condition in order to assure the velocity profile is in fact developed (i.e. with pressure gradient at the inlet)? I've already used zeroGradient for pressure, but it seems to me such condition doesn't agree with definition of developed flow.
Best regards to all and many thanks in advance for any advise.
F. Soares
PS: I found this thread on the subject emphasizing what I mean.
File Type: jpg Screenshot from 2015-09-25 16:46:53.jpg (91.3 KB, 74 views)
FernandoSoares is offline   Reply With Quote
Old   September 28, 2015, 02:57
Nima Samkhaniani
nimasam is on a distinguished road
instead of using zeroGradient, employing fixedFluxPressure at inlet for pressure will consider your concerns. because fixedFluxPressure sets the pressure gradient based on velocity field
Kummi likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 30, 2015, 13:44
Thumbs up
Sorry for the late reply, but thanks for your advise. I am trying to use the b.c. you mentioned but I am getting the following error message
--> FOAM FATAL ERROR:
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
    From function fixedFluxPressureFvPatchScalarField::updateCoeffs()
    in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 151.
FOAM exiting
I must say I am not sure how to set it in my 0/p file. According to the damBreak tutorial
    leftWall
        type            fixedFluxPressure;
        value           uniform 0;
    rightWall
        value           uniform 0;
    lowerWall
        value           uniform 0;
although these are used at walls not at an inlet.
Are you familiar with the proper setting for fixedFluxPressure? What am I missing here?
Once again thank you for your help.
F. Soares
Old   November 17, 2016, 04:18
vidyadhar
vidyadhar is on a distinguished road
Hello Soares,
I am new to openfoam and I would like to simulate fully developed flow through a rectangular channel.
Since you have already tried, can you, please, help me in setting the velocity field for fully developed case.
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   November 17, 2016, 08:40
Originally Posted by vidyadhar View Post
Hello Soares,
Thanks & Regards,
vidyadhar
Hi there, Vidyadhar.
Perhaps what you need for such a geometry is simply the boundaryFoam solver. If I understood correctly, your problem is to find the velocity profile for a developed flow corresponding to a rectangular cross-sectioned pipe. Right? Check the tutorials in
$FOAM_TUTORIALS/incompressible/boundaryFoam
I believe you'll find what you're looking for in there!
Best regards,
Fernando Soares Alves.
PS: Check also this .pdf which summarizes the most used boundary conditions in the former OpenFOAM version 2.3.0. I hope it will also help you.
Old   November 17, 2016, 09:29
vidyadhar
Hi Fernando,
thank you for the quick reply.
Actually, I want to give inlet condition as fully developed flow.
I want to study the flow behavior through a T junction (either with 1 inlet & 2 outlets or with 2 inlets & 1 outlet).
I am using Caelus6.04 version, which is similar to openfoam. I have openfoam 4.1 also.
I find in some forums, for defining fully developed flow at inlet: some are referring to groovyBCs; some are directly modifying their 0/U file.
As you have tried to use fully developed flow conditions at inlet for your geometry, can you please let me know how to implement for my case.
Thanks & Regards,
vidyadhar
Old   November 17, 2016, 12:02
Hi, Vidyadhar.
Actually I couldn't make it work. I've tried this fixedFluxPressure as mentioned above but kept getting the error message. Searching for this BC again today I've also found this blog entry. Ok, it's in japanese but Google translate is here for those sort of things. Besides you can also check the .pdf I mentioned to see the correct sintaxe for such BC.
Greetings and let me know if you could get it to work for your problem.
Old   November 18, 2016, 00:16
vidyadhar
Hello Fernando,
Thank you very much.
I will let you know once I get any output.
Regards,
vidyadhar
Couple outlet to inlet to achieve a fully developed flow. raghu.tejaswi Fluent UDF and Scheme Programming 8 July 18, 2013 09:04
fully developed flow simualtion with fluent bryant_k FLUENT 2 January 1, 2013 11:19
Nusselt numbers for fully developed laminar flow Danro Siemens 8 July 19, 2012 07:22
LRR Rstm pipe flow takes too long to get fully developed kjetil OpenFOAM Running, Solving & CFD 0 February 13, 2010 11:26
fully developed flow JAS FLUENT 4 February 12, 2007 06:01
