boundary conditions of impressible jet injection |
May 8, 2016, 11:22 |
lipf
Hello Foamers,
I am trying to simulate a air jet injection into an heated open ambient. The air is coming out from a pipe (diameter 2mm) with a velocity of 5 m/s and a temperature of 300k. The pressure and temperature of heated open ambient are 1atm and 500k respectively. Obviously, it is an incompressible case, so I used incompressible solver “simpleScalarTransportFoam” that created by myself(implementing a transport equation of scalar “T” into the simpleFoam, and I have tested this solver on other cases, the results have showed the solver is correct). But, when I calculated jet injection, several boundary conditions were tried while all results were wrong. As initial case I am considering a 2D rectangular geometry. Inlet is set on the top side, other sides(left, right, bottom) are all open ambient. If you have any suggestions regarding left, right and bottom boundary conditions(about 0/U, 0/p, 0/T), Please give me some ideas. Any help would be very much appreciated. |
boundary conditions, impressible flow, jet injection |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Turbulent Mass Injection Boundary Conditions | B. Laubacher | Main CFD Forum | 6 | October 16, 1999 11:56 |
