reactingFoam PitzDaily // premixed air-propane |
January 16, 2015, 01:11 |
remi
Rep Power: 12 |
Hello to you, dear Foamers.
I am currently experiencing troubles when trying to use reactingFoam to simulate with LES the Pitz and Daily case with premixed air-propane . It is indeed impossible to start or maintain the combustion using an irreversibleArrheniusReaction reaction. ( No product is ever being created !) I use the following mechanism (Westbrook’s mechanism (1981) ): reactions { Reaction { type irreversibleArrheniusReaction; reaction "C3H8^0.1 + 5O2^1.65 = 3CO2 + 4H2O"; A 8.6e11; beta 0; Ta 15000; } } Everything works fine when I use a methane reaction, with one global step or 4 steps. I tried to simulate my case with methane combustion instead of propane, and after the combustion is well established, I just changed the switched to propane (renaming CH4 into C3H80 and changing the reaction), but the hot products just got convected away and no new products were created. I tried to replace the thermodynamics data of C3H8 by the CH4's in order to see if that could be the problem, but nothing changed.I also tried to increase A a lot, or reduce Ta, without any success. ( I thought the units might have been the issue) I am starting to think that I forgot something ( maybe obvious?) I would like to know what reduced mechanism I should used for propane combustion ( less than 10 steps would be great), in chemkin or openfoam format. For example in http://www.cfd-online.com/Forums/ope...mechanism.html , Robert gives the following mechanism : C3H8 + 1.5O2 -> 3CO + 4H2 CO + 0.5O2 -> CO2 H2 + 0.5O2 -> H2O but I don't know how to find the related coefficients (A,b,Ta). The inlet Bcs for my case are: U=13.3m/s C3H8=0.024 O2=0.20496 N2=0.77104 I am currently using OF2.2.2. I don't know if my problem comes from the mechanism, the mixture equivalence ratio, a file I forgot to change ... Any idea on how to make it work? |
February 20, 2015, 14:38 |
Dmitry
Rep Power: 11 |
hi,
you can try a three-step mechanism from this paper: V. Sabelnikov, Ch. Fureby, LES combustion modeling for high Re flames using a multi-phase analogy, Combustion and Flame 160 (2013) 83–96 It works fine for me. Thx, Dmitry http://www.edcpisofoam.decgroup.org/ |
February 20, 2015, 21:42 |
remi
Rep Power: 12 |
Thanks a lot for your answer Dmitry.
I will try the mechanism asap Remi |
September 7, 2016, 09:39 |
Fabrizio
Rep Power: 9 |
Hi remir I have the same problem with my testcase.
when I write the reaction with exponent like this: CH4^-0.3 + 2O2^1.3 = CO2 + 2H2O Did you solve your problem? Thank you very much Fabri |
how to achieve ignition of premixed flame using ReactingFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 25 | June 12, 2022 04:52 |
How to switch off combustion and reaction in reactingFoam | shenzhou1987 | OpenFOAM Running, Solving & CFD | 16 | October 26, 2017 15:31 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Lean swirled premixed combustion methane air | bisounours | FLUENT | 0 | July 4, 2007 06:52 |
