problem with interfoam on multiple nodes
Old   June 27, 2016, 11:00
Default problem with interfoam on multiple nodes
G. K.
gkara is on a distinguished road
I am facing trouble with running interFoam on a HPC cluster and would really appreciate some help.
My code runs in parallel without problems when it is restricted to a single node. However, when I submit the job on multiple nodes the simulation crashes after it has performed an arbitrary number of time steps. The output for a typical case which was run in parallel (60 cores, i.e. 3 nodes) is given below
Courant Number mean: 1.06878e-05 max: 0.000182367
Interface Courant Number mean: 4.91428e-07 max: 0.000158003
deltaT = 6.62472e-07
Time = 3.914837612e-06
PIMPLE: iteration 1
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.0855268 Min(alpha.water) = 0 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.00011391, Final residual = 1.10544e-06, No Iterations 6
time step continuity errors : sum local = 1.68697e-11, global = 1.55809e-13, cumulative = 3.4914e-11
GAMG: Solving for p_rgh, Initial residual = 7.62066e-05, Final residual = 7.97734e-07, No Iterations 5
time step continuity errors : sum local = 1.21538e-11, global = 8.31624e-15, cumulative = 3.49224e-11
GAMG: Solving for p_rgh, Initial residual = 3.03775e-05, Final residual = 8.72768e-09, No Iterations 10
time step continuity errors : sum local = 1.32912e-13, global = 1.30875e-17, cumulative = 3.49224e-11
ExecutionTime = 76.1 s ClockTime = 79 s
Courant Number mean: 1.29647e-05 max: 0.000228018
Interface Courant Number mean: 5.9077e-07 max: 0.000191552
deltaT = 7.94966e-07
Time = 4.709803933e-06
PIMPLE: iteration 1
GAMG: Solving for p_rgh, Initial residual = 9.46689e-05, Final residual = 9.36175e-07, No Iterations 6
time step continuity errors : sum local = 2.03431e-11, global = 1.79796e-13, cumulative = 3.51022e-11
GAMG: Solving for p_rgh, Initial residual = 6.33264e-05, Final residual = 7.16328e-07, No Iterations 5
The simulation does not appear to diverge, however the simulation crashes and this is a typical error message is given below:
srun: error: node196: task 37: Floating point exception
srun: Terminating job step 109895.0
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
slurmstepd: *** STEP 109895.0 CANCELLED AT 2016-06-23T15:57:08 *** on node019
srun: error: node196: tasks 20-36,38-39: Killed
srun: error: node245: tasks 40-59: Killed
srun: error: node019: tasks 0-19: Killed
Attempting to resolve this issue I have tried many different things which range from playing with the solution method, e.g. use PCG instead of GAMG, use different decomposition methods, e.g. scotch, metis, simple, hierarchical, also played with different schemes but in all cases the problem persists.
To check whether this problem was affecting solely my code, I have also tried to run the damBreakWithObstacle tutorial. This tutorial exhibits many similarities with my code in terms of solution method, etc. For my test, I used the interFoam solver (instead of the inteDyMFoam used by default in the tutorial) with a mesh of (165 165 165) elements and ran it on 60 cores (3 nodes), which corresponds to approximately 75000 cells/processor. Exactly the same problem arises also in this case!
Finally, I should also mention that I use OpenFOAM 2.4.0 which has been compiled using the intelmpi 5.0.3 library.
I would greatly appreciate any ideas on what might cause this problem and how it would be possible to resolve this.
Best regards,
George
gkara is offline   Reply With Quote
Old   July 6, 2016, 09:17
G. K.
Any suggestions?
problem with InterFOAM interface courant number Yage OpenFOAM 6 June 10, 2020 10:45
[snappyHexMesh] SnappyHexMesh, meshing problem with multiple stl's knarftrebron OpenFOAM Meshing & Mesh Conversion 0 March 30, 2015 08:19
interFoam problem: Movement in wrong direction u2947 OpenFOAM Running, Solving & CFD 0 June 17, 2013 06:29
InterFoam / InterDyFoam running problem anon_c OpenFOAM Running, Solving & CFD 1 August 26, 2009 03:54
Multiple Sahdows / Periodicity Problem Michael Pi FLUENT 0 July 11, 2005 07:42
