Explanation of thermophysical variables (e.g. kappa) + tutorial example
Like Tree2Likes
  • 2 Post By Coris
Old   August 4, 2016, 09:09
Default Explanation of thermophysical variables (e.g. kappa) + tutorial example
Bruno
MBttR is on a distinguished road
I was wondering if someone has an overview of the thermophysical variables used in OpenFOAM and their explanation and units? For example I have most difficulty with kappa, I can't seem to figure out what it stands for, nor can Google. I looked in src/transportModels but I'm not sure..
Also, I thought Hf was Heat of Fusion expressed in kJ/kg. For steel this is roughly 260. In the chtMultiRegionFoam/heater tutorial however, this is 0 (see below). Am I wrong? I assume the heater in this tutorial is approximated by steel, judging from the density and Cp.
Thanks!
mixture
    specie
        nMoles      1;
        molWeight   50;
    transport
        kappa   80;
    thermodynamics
        Hf      0;
        Cp      450;
    equationOfState
        rho     8000;
MBttR is offline   Reply With Quote
Old   August 4, 2016, 09:47
Bruno
Hi!
It seems that Hf = 0 for simulations with just one fluid type, as there is no fusion happening. Still looking for kappa though.
Cheers!
http://www.cfd-online.com/Forums/ope...roperties.html
http://www.cfd-online.com/Forums/ope...n-hf-role.html
Old   August 4, 2016, 09:58
Joris C.
Coris is on a distinguished road
kappa is the thermal conductivity
saidc. and madmemed like this.
Coris is offline   Reply With Quote
Old   August 4, 2016, 10:41
Bloerb will become famous soon enough
http://cfd.direct/openfoam/user-guide/thermophysical/ gives a decent description. As mentioned kappa is the thermal conductivity. (not the thermal diffusivity)
Bloerb is offline   Reply With Quote
Old   August 4, 2016, 18:21
Bruno
Thanks Bloerb and Coris! That's in W/(m*K) I assume? I looked over it in the manual, I was scanning for the word kappa and looked over the Greek letter.
Is natural convection automatically active in simpleFoam? I have a heat source using fvOptions, and am afraid the temperature will just keep increasing into infinity. I am solving a single heater in a body of air. I think I am confusing convection and conduction. Is this kappa (thermal conductivity) defininig natural convection and is forced convection following from my boundary conditions on e.g. U?
Cheers!
Old   August 5, 2016, 03:35
Joris C.
You have to use chtMuliRegion(Simple)Foam or one of the Boussinesq solver for that. Here is a good overview: https://github.com/OpenFOAM/OpenFOAM...s/heatTransfer
What is your exact geometry and BC? I am also studying a case with NC (natural convection).
Thermal conductivity is in W/(mK) yes. I think you have to check some theory or at least look at some heat transfer correlations. They will make clear which quantities are important. Generally, this are the Reynolds and Prandtl numbers for forced and Grashof and Prandtl for natural convection.
Old   August 5, 2016, 04:37
Bruno
Ah yes Coris, my bad, I meant chtMultiRegionSimpleFoam, not simpleFoam I asked about the units mainly because OpenFOAM sometimes does some division that you need to be aware of (which I guess is mainly in the case of things related to dynamic pressure), or works in different units as expected.
Anyway! I was just about to post before you posted, I think I get it.
Natural convection is governed by the Rayleigh number. This requires kinematic viscosity, which can be calculated from dynamic viscosity and rho. It requires thermal diffusivity, which can be calculated from kappa, rho and cp. It require the thermal expansion coefficient which can be approximated by 1/T. Forced convection is just governed by the same coefficients, with the addition of velocity.
Conduction seems to be pretty much just governed by kappa and is the exact same thing as diffusion.
Please let me know if I am right at all. I was confused and posted this thread because indeed I was not seeing all the relations behind it and wanted to know if all methods of heat transfer were governed by just these few thermphysical properties. I also think it's not a matter of "activating" forced or free convection, as they are always present in these heat transfer solvers?
Also my solution did indeed stabilize, just at a way too high temperature than expected from testing. Now that I know the variables better, I can try again.
And concerning my geometry: I am researching the heating of an electric motor with a rotor. The rotor is not present in the model, the motor is just modelled as a ring, representing the motor coils. This is of course an approximation, since I now still model the coils as one material block while in reality there are slots and it is made of copper and iron. I do think however I should be able to get close enough by using average values. I'll update this post in a few minutes from my linux machine with BCs.
Cheers, thanks!
*edit*
Boundary Conditions. So remember I have an air volume shaped as a block with air flowing in on one side and flowing out the other. These are not exact copies, I edited them to shorten the post For the air volume:
T
internalField   uniform 294;
boundaryField
    minX, maxX, minY, maxY, minZ and maxZ
        type            zeroGradient;
        value           uniform 294;
    air_to_motorcoil
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 294;
        Tnbr            T;
        kappaMethod     fluidThermo;
U (very low velocity) I should probably make minY, maxY, minX and maxX zeroGradient in stead of fixedValue to better approach my test values, which were on a bench in open space.
internalField   uniform ( 0 0 0.1 );
boundaryField
    minZ
        type            fixedValue;
        value           uniform ( 0 0 0.1 );
    maxZ
        type            inletOutlet;
        inletValue      uniform ( 0 0 0 );
        type            fixedValue;
        value           uniform ( 0 0 0 );
    air_to_motorcoil
        type            fixedValue;
k
internalField   uniform 0.1;
boundaryField
    minZ
        type            fixedValue;
        value           uniform 0.1;
    maxZ
        type            inletOutlet;
        value           uniform 0.1;
        inletValue      uniform 0.1;
        type            kqRWallFunction;
        value           uniform 0.1;
    air_to_motorcoil
        value           uniform 0.1;
For the coils:
T:
internalField   uniform 300;
boundaryField
    motorcoil_to_air
        value           uniform 294;
        Tnbr            T;
        kappaMethod     solidThermo;
U:
internalField   uniform (0 0 0);
boundaryField
    motorcoil_to_air
        type            calculated;
        value           uniform (0 0 0);
k:
internalField   uniform 0;
boundaryField
    motorcoil_to_air
        type            calculated;
        value           uniform 0;
Also have this fvOptions in motorcoil/system:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
volumetricHeatSource
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        volumeMode      absolute;
        selectionMode   all;  //cellSet // points //all  (other options)
        injectionRateSuSp
            h (40 0);   // S(T)=S_u+S_p*T  ===>  S_u=g    S_p=0
        }              // g= specific volumetric generation (W/m3)
    }                  // g= absolute volumetric generation (W) ===> in the example 3W are considered
Old   August 5, 2016, 04:50
Joris C.
Cheers, thanks!
You can deactivate NC by making the density independent of temperature. That works for eg water, but I don't know by heart how it works for gases (can you set beta to zero explicitly?).
Old   August 5, 2016, 05:03
Bruno
I'm not familiar enough with heat transfer problems to judge whether NC is negligible. Surely, even with a fan this must still play some effect?
And I don't think you can specify beta specifically.
Updated my post with BCs, if you can take a look at that?
Cheers!
Old   August 5, 2016, 05:53
Bruno
If I switch my boundaries on U from fixedValue (0 0 0) to zeroGradient my air temperature decreases (already under 0°C and descending), which clearly doesn't make sense. Any clue what's wrong?
Old   August 8, 2016, 02:34
Joris C.
Seeing your heat source, my first guess is that it's role will be negligible in NC. But you can check it by setting g to 0.
There is something odd with your BC's. You should set the inlet velocity at and zeroGradient pressure at the inlet side and zeroGradient velocity and zero pressure at the outlet.
The problem you experience is related to the BC for temperature. I advise to set it to inletOutlet.
Accessing thermoPhysical Property Functions - e.g. mixture_.rho(scalar p, scalar T) will.logie OpenFOAM Programming & Development 2 June 23, 2015 23:38
Explanation of airFoil2D tutorial in OpenFOAM akku OpenFOAM Running, Solving & CFD 0 February 28, 2013 00:21
