Strange chtMultiRegionFoam behaviour - temperature drops during heating
Old   November 8, 2016, 16:03
Default Strange chtMultiRegionFoam behaviour - temperature drops during heating
Petr Furmanek
petr.f. is on a distinguished road
Hi guys,
recently I've been playing with chtMultiRegionFoam but cannot get it to work. My test case is simple - an iron ball hanging in the air with the initial temperature of 300 K over which I blow the air with temperature of 620 K. I'd like to see the ball slowly heating. However in a really short time the temperature in the vicinity of the ball starts to drop and continues dropping towards the absolute zero until the solver diverges. I attach the configuration files - nothing fancy, I've just used the tutorial settings and tweaked them a bit. The mesh is generated in snappy and is of quite a decent quality.
the max Courant Nos I use are
maxCo 0.5;
// Maximum diffusion number
maxDi 10.0;
and for the boundary conditions for temperature I prescribe the standard options for inlet/outlet and for T
fluid region:
domain0_to_ball
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value uniform 620;
Tnbr T;
kappaMethod fluidThermo;
solid region:
ball_to_domain0
value uniform 300;
Tnbr T;
kappaMethod solidThermo;
I've done quite a lot computations with chtMultiRegionSimpleFoam but never seen such a behaviour... So any help would be really appreciated.
Configuration for the fluid region:
fvSchemes
ddtSchemes
    default                   Euler;
gradSchemes
    default                   Gauss linear;
    grad(U)                   cellLimited Gauss linear 1;
divSchemes
    default                   none;
    div(phi,U)                bounded Gauss linearUpwindV grad(U);
    div(phi,h)                bounded Gauss upwind;
    div(phi,e)                bounded Gauss upwind;
    div(phi,K)                bounded Gauss upwind;
    div(phi,k)                bounded Gauss upwind;
    div(phi,R)                bounded Gauss upwind;
    div(R)                    Gauss linear;
    div(phi,epsilon)          bounded Gauss upwind;
    div(phi,omega)          bounded Gauss upwind;
   div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default                   Gauss linear corrected;
interpolationSchemes
    default                     linear;
wallDist
    method meshWave;
snGradSchemes
    default                   corrected;
fluxRequired
    default                     no;
    p;
fvSolution
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-7;
        relTol          0.1;
    rhoFinal
        $rho;
        tolerance       1e-7;
        relTol          0;
    "(p_rgh|p)"
        solver           GAMG;
        tolerance        1e-7;
        relTol           1e-2; // def. 1e-2
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
        minIter          2;
        maxIter          50;
    p_rghFinal
        $p_rgh;
        tolerance        1e-7;
        relTol           0;
    "(U|h|e|k|epsilon|omega|R)"
        solver           smoothSolver;
        smoother         DILUGaussSeidel;
        tolerance        1e-7;
        relTol           0.1;//0.01;// def. 0.1;
        nSweeps          2;
    "(U|h|e|k|epsilon|omega|R)Final"
        $U;
        tolerance        1e-7;
        relTol           0;
PIMPLE
    momentumPredictor   on;
    nCorrectors         2;
    nOuterCorrectors    2;
    nNonOrthogonalCorrectors 0;
relaxationFactors
  rho               1;
  "(p_rgh|p)"       0.7;
  U                 0.3;
  "(h|e)"           0.3;
  k                 0.8;
  "(epsilon|omega)" 0.8;
Configuration for the solid region:
fvSchemes:
ddtSchemes
    default Euler;
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default             none;
    laplacian(alpha,h)  Gauss linear corrected;
    default         linear;
snGradSchemes
    default         corrected;
fvSolution
solvers
    h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
    hFinal
        $h;
        tolerance        1e-06;
        relTol           0;
PIMPLE
P.
petr.f. is offline   Reply With Quote
Old   December 8, 2016, 05:53
Petr Furmanek
Got it solved - the (obvious) error was in usage of the bounded schemes, should anyone be interested...
Old   December 23, 2016, 06:03
Manu Chakkingal
manuc is on a distinguished road
@petr.f.
How did u solve this issue , Is it just by using some unbounded schemes?
Thanks
Regards
Manu
manuc is offline   Reply With Quote
Old   January 24, 2017, 07:54
Petr Furmanek
Just remove the "bounded" keyword. Detailed explanation is here:
http://openfoam.org/release/2-2-0/numerics-boundedness/
Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle TobM OpenFOAM Running, Solving & CFD 2 May 11, 2016 06:34
[sprayFoam] strange spray formation behaviour pbalz OpenFOAM Running, Solving & CFD 0 March 23, 2015 11:41
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 14:00
Strange residuals behaviour xxxx Main CFD Forum 1 July 13, 2013 14:40
Strange behaviour when using LienCubicKE and NonlinearKEShih hani OpenFOAM Running, Solving & CFD 20 March 6, 2013 10:06
