Can not add force to Equn in interFoam,Help
Old   August 22, 2016, 07:10
Default Can not add force to Equn in interFoam,Help
zhibin wang
zhibin.wang is on a distinguished road
Dear OpenFoam users
I am a new openFoam user. These days, I am trying to simulating the droplet deformation and breakup in gas air flow.The droplet will move because of the drag force exerted by air stream.In order to decrease the field gemotry and computation cost,I plan to give a force to keep the drop at a constant position or slow it down. The force only exert to water phase according the alpha1. I have tried two schmes.The both scheme can compile and run without any error, but the result is not what I want,no matter the value of the force, the droplet is still move with the same velocity as before. It seems that the force don’t exert on the drop successfuly.
So I think there is some problem with my schemes.
The first Scheme: add the force to the UEqn, like the way how the gravity is added.
This scheme was used by the former OpenFoam users.
http://www.cfd-online.com/Forums/ope...y-gravity.html.
The revised code as follow:
MRF.correctBoundaryVelocity(U);
fvVectorMatrix UEqn
fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
+ MRF.DDt(rho, U)
+ turbulence->divDevRhoReff(rho, U)
fvOptions(rho, U)
//- gg*alpha1*rho//I also try to add it here, but failed.
UEqn.relax();
fvOptions.constrain(UEqn);
if (pimple.momentumPredictor())
solve
UEqn
fvc::reconstruct
mixture.surfaceTensionForce()
- ghf*fvc::snGrad(rho)
- fvc::snGrad(p_rgh)
) * mesh.magSf()
- gg*alpha1*rho // Where gg is a uniformdimensionedVectorfield as g (Graviy field).
fvOptions.correct(U);
[COLOR="red"]In this Scheme, I also tried from “- gg*alpha1*rho” to “+ gg*alpha1*rho”, and try to change the value from (0 -9.81, 0) to (0 -9810, 0),but the results are same.
[/COLOR]
The second scheme is to creative a surfaceScalarField gggf as ghf ,and add it to UEqn and PEqn.
fvVectorMatrix UEqn
+ MRF.DDt(rho, U)
fvOptions(rho, U)
UEqn.relax();
solve
UEqn
fvc::reconstruct
- (ghf +gggf)*fvc::snGrad(rho)//where the gggf is a surfaceScalarField
) * mesh.magSf()
gggf was created as follow.
IOobject
"gggf",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
fvc::interpolate(alpha1)*(gg & mesh.Cf())//
where gg is also a is a uniformdimensionedVectorfield same as g (Graviy field).In this scheme,the PEqn is also revised as follows.
surfaceScalarField phig
- (ghf + gggf)*fvc::snGrad(rho) //
//- (fvc::interpolate(VectorFF) & mesh.Sf())/pow(mesh.magSf(),2)
)*rAUf*mesh.magSf()
I am not sure whether is it correct to revise the PEqn.Because the ghf appear in PEqn,so I think it is necessary to revise it, because the gggf is same as ghf.
The droplet diameter is 2mm.
blockMeshDict Code
blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(0.01 0 0)
(0.01 0.01 0)
(0 0.01 0)
(0 0 0.01)
(0.01 0 0.01)
(0.01 0.01 0.01)
(0 0.01 0.01)
blocks
hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1)
patches
patch inlet
(1 5 4 0)
patch outlet
(3 7 6 2)
wall walls
(0 4 7 3)
(2 6 5 1)
U boundary condition code
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 5 0);
boundaryField
inlet
type fixedValue;
value uniform (0 5 0);
outlet
type zeroGradient;
walls
type zeroGradient;
// value uniform (0 0 0);
P_rgh boundary condition code
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 100;
boundaryField
inlet
type fixedValue;
value uniform 100;
outlet
type zeroGradient;
//value uniform 1e-05;
walls
type zeroGradient;
value uniform 0;
transportPropertied code
phases (water air);
water
transportModel Newtonian;
nu [0 2 -1 0 0 0 0] 1e-06;
rho [1 -3 0 0 0 0 0] 1000;
air
nu [0 2 -1 0 0 0 0] 1.48e-05;
rho [1 -3 0 0 0 0 0] 1;
sigma [1 0 -2 0 0 0 0] 0.07;
I am working on the problem for two weeks, but I still don’t know what wrong with my Schemes or code.Would you like give me some suggestions?
Thank you.
Best regards.
Zhibin wang
zhibin.wang is offline   Reply With Quote
add brownian force to twophaseEulerFoam solver hoseinhd OpenFOAM Running, Solving & CFD 0 August 21, 2016 07:40
Force on moving body joechorn Fluent UDF and Scheme Programming 5 April 2, 2015 11:25
Add time-dependent force paul_oborin OpenFOAM Running, Solving & CFD 0 April 2, 2013 04:41
how to add a force in the momentum equation guillaumem OpenFOAM 0 June 14, 2010 03:49
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
