Running reactingFoam in turbulence mode
Old   September 19, 2016, 01:15
Default Running reactingFoam in turbulence mode
chen king arthur
samchen1993 is on a distinguished road
Hi guys anyone knows how to run reactingFoam in tubulence mode? Please help anything needed to bedone besides changing the simulationType in turbulence properties?
samchen1993 is offline   Reply With Quote
Old   September 25, 2016, 16:16
Retired Super Moderator
Bruno Santos
Quick answer: In principle, it should be possible to use turbulence in reactingFoam the same way as in the tutorial cases at "compressible/rhoPimpleFoam/".
Nonetheless, I have not tested this myself and it's possible that reactingFoam only supports a few turbulence models. In order to know which ones work, you can use this trick: http://openfoamwiki.net/index.php/Op...de/Use_bananas
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
Les turbulence model in steady mode shahrbanoo FLUENT 2 April 18, 2016 11:00
Having problems running transient fluent simulation in batch mode obylong FLUENT 1 August 14, 2014 23:58
Running macros in parallel in batch mode nomad STAR-CCM+ 13 February 22, 2013 08:30
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
