Wall function for concrete walls, open channel flow |
November 7, 2016, 04:52 |
Tinu
Rep Power: 9 |
Hi everybody,
I am using OpenFoam to simulate a weir situation in an open channel flow, see attached link. Im am using interFoam / interDyMFoam for this case. Basically I get the simulation to work, and the results overall look OK to me. However, I am struggling a bit to find/use the "best" turbulence modelling, meshing at walls and wall functions. -The whole geometry is made of concrete of the same roughness -At the moment I am using the Standard high-Re k-epsilon model (RASModel kEpsilon) -At wall boundaries, I use fixedValue uniform(0,0,0) for U, kqRWallFunction uniform 1e-20 for k, epsilonWallFunction uniform 1e-07 for epsilon, nutUSpaldingWallFunction uniform 0.001 for nut. Those boundary conditions and the values itself are defined when using Helyx-OS and defining the geometry as "wall", so basically standard suggestion from Helyx-OS. My question is: -Has anyone who is working on similar cases a suggestion which wall functions are best used to model the impact of roughness from concrete walls? Which values would you be using for those wall functions? -Would you suggest a different turbulence model for this case? -What would be your strategy when meshing, especially at walls in order to get the wall functions work how they are supposed to? Any help on this is greatly appreciated! I know that I probably have to dive a bit deeper into wall functions an turbulence modelling, however having some hints for this one would greatly help me. Tinu ...edit: picture upload isn't working for me at the moment. will try to fix this. Just think of a broad crested weir in a ca. 15 m wide channel. Last edited by tinu80; November 7, 2016 at 05:00. Reason: picture upload doesn't work |
November 8, 2016, 08:46 |
Paulo Vatavuk
Rep Power: 17 |
HI Tinu,
To model the effect of roughness you could use the nutkRoughWallFunction for nut. The data for this boundary condition are: type nutkRoughWallFunction Ks - The Moody diagram roughness in meters Cs - The roughness constant. The value is normally 0.5 value - Initial estimate for nut in the iterative calculation The book “Fluid Mechanics” of F. M. White suggests a value of Ks=0.00004 m for smoothed concrete and Ks=0.002 m for rough concrete. Best Regards, Paulo |
November 8, 2016, 16:24 |
Tinu
Rep Power: 9 |
Dear Paulo,
Thank you very much for your suggestion! nutkRoughWallFunction is exactly what I am playing around with at the moment, so good to know I am looking in the right place! Maybe you can help me with my other question about mesh size at walls for nutkRoughWallFunction. Which y+ values should I have for my mesh at walls? Best regards, Tinu |
November 8, 2016, 19:51 |
khedar
Rep Power: 9 |
Hi Tinu,
If you are asking about the mesh size at the boundary for your case then you should keep the first cell size such that your y+ > 30. This is so that it lies in the turbulent region and not in the near wall viscous region. regards, khedar |
November 9, 2016, 07:36 |
Tinu
Rep Power: 9 |
Hi khedar,
Thanks for your help. I think I get it now. How important is the maximum allowable value of y+? The suggested values I found in literature are between 100 to 300. In my case, my y+ is much higher, around 5000. My plan is to calibrate the model based on known discharges and water levels. So I basically would try to change the Ks value in nutKRoughWallFunction until the simulation matches the experimental data. So, even if I have underestimated wall shear stress because of too high y+, I could "correct" this by changing Ks value? Does that make sense somehow? With y+ around 100 my mesh would get way too big to handle. Best regards, Tinu Last edited by tinu80; November 9, 2016 at 07:47. Reason: typo |
November 9, 2016, 10:30 |
khedar
Rep Power: 9 |
Hi Tinu,
i am no expert on wall function approach and am still in learning phase And hence i will suggest you the following discussion which you may find useful: http://www.cfd-online.com/Forums/flu...treatment.html 1. From my basic understanding of Boundary layers, i would say that keeping your y+ too far above 300 will lead to some inaccuracies in solution(how big, can't say). This is because above this y+ one comes out of the boundary layer and into core turbulent flow region and the wall function predicted values may not be that accurate. 2. changing the k values in the wall function approach: can't say if this is the right approach(engineering approach ). regards, khedar |
November 9, 2016, 11:16 |
#7 | |
Tinu
Rep Power: 9 |
Thanks again for your support. You are right, I am looking for some engineering approach :-) From playing with different Ks values I can say that it has a big impact to mean velocities and consequently to flow depth in the channel flow. It is comparable to changing Strickler or Mannings values in 2d or 1d open channel hydraulics. But it is quite hard to find hints on calibrating 3d open channel cases. Regards, Tinu |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
