November 4, 2016, 01:50 |
InterFoam - no convergence
Rep Power: 9 |
Hey openFoam users
I'm trying to simulate the flow through a cylindric unit (3 inlets at the top, 6 outlets at the bottom). Now I'd like to make a 2D simulation of a slice (middle of the cylindric unit) such that the flow distribution is visible. As far as I know, openFoam operates in 3D. I am drawing and meshing the unit in Salome. There I created a slice of the unit, which is still 3D though. Can I import this slice into openFoam and assign the front and the back side as empty patch? I tried it and the program did no converge (I indicated the front and back side as empty patch in the alpha boundary folder as well as in U and p.) What is my mistake? Or is there another way of just simulating a 2D slice? I want to do that because I think it is a easier way to look at the flow distribution. I am very happy about any help as I am a rather new openFoam user :-) Best, Ann |
November 4, 2016, 03:16 |
Kevin van As
Rep Power: 20 |
A 2D simulation in OpenFOAM is simply a 3D simulation with only one cell thickness in the third dimension and boundary condition "empty".
An alternative that could be of use to you is an axis-symmetrical simulation: use the "wedge" boundary condition. A common reason for interFoam to behave strangely is the way in which you specify your inlet. Did you attach an inlet pipe for each inlet, or do you set all different velocities/alphas on the same patch? The latter will not behave properly (in my experience). |
November 6, 2016, 18:15 |
Rep Power: 9 |
Thanks for the reply and sorry for answering late.
That might be a stupid question, but how do I create a "one cell thickness in the third dimension" ? Does this mean 1 mm or what is meant by cell? I do not have inlet pipes (just 3 wholes in the upper part of the unit). I created an inlet group with all three faces and use them in the program as one patch. |
November 7, 2016, 03:46 |
#4 | ||
Kevin van As
Rep Power: 20 |
It was weekend, hence it is not late at all.
blocks ( hex (0 1 2 3 4 5 6 7) (32 32 1) simpleGrading (1 1 1) ); Quote:
Does this mean that you have a "wall" and an "inlet" on the same face? That is, on the same height? If so, that might mean trouble. Have a look at this tutorial. If you were to remove the inlet pipe above the box and just specify the inlet at the same height as the atmosphere, your simulation will not behave physical (or diverge even). |
November 8, 2016, 22:06 |
Rep Power: 9 |
Okay, thank you very much!
I will have a look at the tutorial you gave me :-) Another question: In another set-up I used the command pre.cjk { font-family: "Nimbus Mono L",monospace; }p { margin-bottom: 0.1in; line-height: 120%; } transformPoints -scale '(0.001 0.001 0.001)' to transform the geometry (with was drawn in mm dimension) to m dimension for OpenFOAM. If I do so, the program does not converge anymore I tried then to run the program without the transformation command, which is wrong I know, as the dimensions are totally wrong then. Buuut then the program works. Do you have an idea, where the problem lays? Thank you :-) |
November 9, 2016, 02:53 |
Kevin van As
Rep Power: 20 |
That's a completely different question - never heard of that method and it looks pretty weird: why do you need a font to transform a mesh...?
November 9, 2016, 03:29 |
Rep Power: 9 |
I am sorry, there was a mistake with copy paste.
I use the command transformPoints -scale '(0.001 0.001 0.001)' in the terminal. As I import a mesh (ideasUnvToFoam) which is drawn in other dimensions. I hope it is more understandable now. |
November 9, 2016, 08:11 |
Arne
Rep Power: 12 |
since you reduced the size of the cells but the the physics of your flow (velocity etc..) remained the same, you should probably reduce the time step. A Courant lower then 1 is good for interfoam as the alpha equation is solved explicitly.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
Convergence Test on InterFoam | rcarmi | Main CFD Forum | 0 | December 18, 2014 15:20 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
