externalWallHeatFluxTemperature - Temperature internal domain
Old   November 25, 2016, 06:01
Default externalWallHeatFluxTemperature - Temperature internal domain
Sarah Leenknegt
SarahLee is on a distinguished road
Dear all,
I am testing the BC externalWallHeatFluxTemperature on a simple case: room with window in contact with outdoor air. These are my boundary conditions:
- exterior air temperature Ta: -4 °C = 269.15 K
- exterior heat transfer coefficient h = 25 W/(mēK)
- glass between exterior and interior domain: R = 1.73 m2K/W, d = 0.02 m, lambda = 0.012 W/(mK)
- interior temperature appr. 20 °C
I implement this as follows:
glass
     type            externalWallHeatFluxTemperature;
     kappa           lookup;
     Ta              uniform 269.15;                    //external air temperature K
     h               uniform 25;                             //external heat transfer coefficient (W/mēK)
     thicknessLayers (0.020);                      //thickness glass (m)
     kappaLayers     (0.012);                         //equivalent heat conductivity glazing W/(mK)
     kappaName       alphaEff;
     value           uniform 273.15;
Is this correct?
In the resulting interior flow field, the air temperature just adjacent to this wall is -4 °C. This doesn't make sense to me, as this value should be implemented outside the interior flow domain?
Some feedback is appreciated!
Sarah
SarahLee is offline   Reply With Quote
Old   November 25, 2016, 08:36
Sarah Leenknegt
Dear foamers,
In an attempt to better understand this boundary condition, I did a quick and dirty parameter variation on a simple block. I varied the following parameters:
- h = 1 or 10 W/mēK
- thicknessLayers = 0.2 or 20 m
- kappaLayers = 1 or 5 W/mK
and plotted the results after 1000 iterations. They look basically nearly identical. I have attached a pdf with some screenshots.
Why doesn't it seem to matter what is between my exterior temperature of 300 K and my internal field?
Thanks!
Sarah
Old   April 20, 2017, 15:38
wc3speler is on a distinguished road
Hi!
Did you find out why the temperature in the internalField near the wall turns out to be what you specified for the outside domain?
wc3speler is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Temperature lower than possible in closed domain Czarulla Main CFD Forum 1 January 15, 2015 05:01
Closed domain - temperature problem? Czarulla Main CFD Forum 0 January 7, 2015 08:18
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 04:56
