November 20, 2016, 07:54 |
Reynolds Stress Model (for example LRR)
ali
Rep Power: 9 |
Dear All, I want to use Reynolds Stress Model (for example LRR) at OpenFOAM but I do not know how to use and define at the software?
Please help me. |
November 22, 2016, 02:47 |
ali
Rep Power: 9 |
Where is someone to help me???
Thanks in advance |
November 22, 2016, 10:42 |
Ardalan
Rep Power: 13 |
Please give more details,
LRR needs epsilon and R file to start, Ardalan |
November 22, 2016, 11:16 |
The error in file R (model LRR)
ali
Rep Power: 9 |
Hi, Thanks for your reply,
My case is a CYCLONE. I want to use Reynolds Stress Model (LRR) at OpenFOAM but I do not know how to use and define at the software. To begin, I found a file R and changed it. My boundary conditions are inlet, outlet and walls. File U is as fallow: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { walls { type noSlip; } inlet { type pressureInletOutletVelocity; value uniform (-10 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } } File R is as fallows: dimensions [0 2 -2 0 0 0 0]; internalField uniform (0 0 0 0 0 0); boundaryField { wallS { type kqRWallFunction; value uniform (0 0 0 0 0 0); } inlet { type pressureInletOutletVelocity; value uniform (0.0015325 0 0 0.0015325 0 0.00306504); } outlet { type zeroGradient; } } According to the file U, What changes do I need on R? Have you a file R to send for me? I need the fvSolution and fvSchemes files for model LRR. Best, Ali |
November 22, 2016, 11:21 |
ali
Rep Power: 9 |
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for walls file: /home/dadehnegar/OpenFOAM/dadehnegar-4.0/run/project/MYcyclone/air+water/rsmLRR/0/R.boundaryField from line 25 to line 37. According to the files U and R in previous comment, help me to solve this error please. Thanks Ali |
November 22, 2016, 11:55 |
Ardalan
Rep Power: 13 |
Please check the spelling for walls in R file.
and let me know? |
November 22, 2016, 13:32 |
ali
Rep Power: 9 |
Hi, the error was solved. Except the file R, What other changes are needed for model LRR?
Now I think that the fvSolution file and the fvSchemes must be changed based on file R. Do you agree? Please send me a example of these files for model LRR. Thanks, Ali |
November 23, 2016, 04:14 |
Ardalan
Rep Power: 13 |
Report the error, then I will help you.
It seems you have big y+ close to the wall. I recommend to use y+~1 and start with LaunderSharmaKe. fvSchmes and fvSolution for LRR is not something special. Add an alforithem for R in fvSolution and appropriate shcmes in fvScheme. Ardalan |
November 23, 2016, 10:13 |
#9 | |
ali
Rep Power: 9 |
--> FOAM FATAL IO ERROR: [4] attempt to read beyond EOF [4] [4] file: IOstream.divSchemes.div(phi,R) at line 0. [4] [4] From function virtual Foam::Istream& Foam::ITstream::read(Foam::token&) [4] in file db/IOstreams/Tstreams/ITstream.C at line 82. [4] FOAM parallel run exiting [4] [3] file: IOstream.divSchemes.div(phi,R)[7] at line 0. [3] [3] From function virtual Foam::Istream& Foam::ITstream::read(Foam::token&) [3] in file db/IOstreams/Tstreams/ITstream.C at line 82. [3] FOAM parallel run exiting ----------------------------------------------------------------------------------------------------------------- fvSchemes: FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(phi,R) bounded Gauss limitedLinear; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // |
November 23, 2016, 10:24 |
#10 | |
ali
Rep Power: 9 |
November 23, 2016, 12:59 |
#11 |
Ardalan
Rep Power: 13 |
Change all schemes to upwind.
Put all your boundary conditions to something same. You had noSlip. Put fixedValue. Try it! Ardalan |
November 23, 2016, 13:02 |
fvSchemes file
#12 |
ali
Rep Power: 9 |
Hi, in the first stage, fvSchemes file is as fallow:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } the error file is attached for above file. |
November 23, 2016, 13:16 |
#13 |
Ardalan
Rep Power: 13 |
you have not defined div(phi,R).
Simply define: div(phi,R) Gauss upwind; Most likely you will receive similar errors for other schemes. Add them and put upwind. Ardalan |
November 23, 2016, 14:52 |
#14 |
ali
Rep Power: 9 |
Thanks. I solved the errors at the fvSchemes file. Now I got a another error at the fvSolution file is as fallow:
[0] --> FOAM FATAL IO ERROR: [0] keyword RFinal is undefined in dictionary "/home/dadehnegar/OpenFOAM/dadehnegar-4.0/run/project/MYcyclone/air+water/rsmLRR/system/fvSolution.solvers" [0] [0] file: /home/dadehnegar/OpenFOAM/dadehnegar-4.0/run/project/MYcyclone/air+water/rsmLRR/system/fvSolution.solvers from line 22 to line 63. fvSolution: solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; } "(U|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0; minIter 1; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 0; } relaxationFactors { equations { ".*" 1; } } Please help me. Best, Ali |
November 24, 2016, 02:11 |
#15 |
Ardalan
Rep Power: 13 |
Please read the tutorials, these are basics in OpenFoam.
You use pimple algorithem and it need RFinal in fvSolution. Introduce it. Have fun! Ardalan |
November 24, 2016, 11:52 |
#16 |
ali
Rep Power: 9 |
Hi, How do I add this option (RFinal)? Where? Can you introduce a fvSolution file that it has a Simple algorithem?
Thanks in advance, Ali |
November 24, 2016, 12:52 |
#17 |
Ardalan
Rep Power: 13 |
put this in you fvSolution
"(R|RFinal)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-9; relTol 0.01; nSweeps 1; }; see if it works! Ardalan |
November 25, 2016, 05:48 |
#18 |
ali
Rep Power: 9 |
November 25, 2016, 06:00 |
#19 |
ali
Rep Power: 9 |
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0.000120212, Final residual = 2.15417e-10, No Iterations 2 Phase-1 volume fraction = 0.961255 Min(alpha.water) = -4.52004e-13 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.961255 Min(alpha.water) = -3.40531e-07 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0476108, No Iterations 632 time step continuity errors : sum local = 508582, global = -1554.68, cumulative = -1554.68 DICPCG: Solving for p_rgh, Initial residual = 1.52076e-11, Final residual = 1.52076e-11, No Iterations 0 time step continuity errors : sum local = 9.09126e+13, global = 402788, cumulative = 401233 DICPCG: Solving for p_rgh, Initial residual = 1.57267e-11, Final residual = 1.57267e-11, No Iterations 0 time step continuity errors : sum local = 9.40157e+13, global = 1.78437e+12, cumulative = 1.78437e+12 [1] [5] #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? at ??:? [5] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib/x86_64-linux-gnu/libc.so.6" [5] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? at ??:? [1] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const[5] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? [1] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [5] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [1] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? [5] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? [5] #7 at ??:? [1] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::diction ary const&) at ??:? [5] #8 at ??:? [1] #8 Foam::fvMatrix<double>::solve() at ??:? [5] #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&)Foam::fvMatrix<double>::solve() at ??:? [5] #10 Foam::RASModels::LRR<Foam::IncompressibleTurbulenc eModel<Foam::transportModel> >::correct() at ??:? [1] #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? [5] #11 at ??:? [1] #10 Foam::RASModels::LRR<Foam::IncompressibleTurbulenc eModel<Foam::transportModel> >::correct()? at ??:? [1] #11 at ??:? [5] #12 __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6" [5] #13 at ??:? [1] #12 __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #13 at ??:? [DNCO:05536] *** Process received signal *** [DNCO:05536] Signal: Floating point exception (8) [DNCO:05536] Signal code: (-6) [DNCO:05536] Failing at address: 0x3e8000015a0 ?[DNCO:05536] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7f2942ef8cb0] [DNCO:05536] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7f2942ef8c37] [DNCO:05536] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7f2942ef8cb0] [DNCO:05536] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6sm oothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5 _RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduI nterfaceFieldEEEhi+0x2f5) [0x7f29440b4d35] [DNCO:05536] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6s moothERNS_5FieldIdEERKS2_hi+0x2d) [0x7f29440b510d] [DNCO:05536] [ 5] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5 FieldIdEERKS2_h+0x3a7) [0x7f29440afc97] [DNCO:05536] [ 6] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x11e) [0x7f29463c7afe] [DNCO:05536] [ 7] interFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictio naryE+0x108) [0x49a528] [DNCO:05536] [ 8] interFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xcb) [0x49a7cb] [DNCO:05536] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam5solv eIdEENS_17SolverPerformanceIT_EERKNS_3tmpINS_8fvMa trixIS2_EEEE+0x27) [0x7f29479d31b7] [DNCO:05536] [10] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam9RASM odels3LRRINS_29IncompressibleTurbulenceModelINS_14 transportModelEEEE7correctEv+0x533) [0x7f2947a2a343] [DNCO:05536] [11] interFoam() [0x439aa9] [DNCO:05536] [12] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f2942ee3f45] [DNCO:05536] [13] interFoam() [0x43e479] [DNCO:05536] *** End of error message *** at ??:? [DNCO:05532] *** Process received signal *** [DNCO:05532] Signal: Floating point exception (8) [DNCO:05532] Signal code: (-6) [DNCO:05532] Failing at address: 0x3e80000159c [DNCO:05532] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fe1059ebcb0] [DNCO:05532] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7fe1059ebc37] [DNCO:05532] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fe1059ebcb0] [DNCO:05532] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6sm oothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5 _RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduI nterfaceFieldEEEhi+0x2f5) [0x7fe106ba7d35] [DNCO:05532] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6s moothERNS_5FieldIdEERKS2_hi+0x2d) [0x7fe106ba810d] [DNCO:05532] [ 5] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5 FieldIdEERKS2_h+0x3a7) [0x7fe106ba2c97] [DNCO:05532] [ 6] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x11e) [0x7fe108ebaafe] [DNCO:05532] [ 7] interFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictio naryE+0x108) [0x49a528] [DNCO:05532] [ 8] interFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xcb) [0x49a7cb] [DNCO:05532] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam5solv eIdEENS_17SolverPerformanceIT_EERKNS_3tmpINS_8fvMa trixIS2_EEEE+0x27) [0x7fe10a4c61b7] [DNCO:05532] [10] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam9RASM odels3LRRINS_29IncompressibleTurbulenceModelINS_14 transportModelEEEE7correctEv+0x533) [0x7fe10a51d343] [DNCO:05532] [11] interFoam() [0x439aa9] [DNCO:05532] [12] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fe1059d6f45] [DNCO:05532] [13] interFoam() [0x43e479] [DNCO:05532] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 5532 on node DNCO exited on signal 8 (Floating point exception). |
November 25, 2016, 06:24 |
#20 |
ali
Rep Power: 9 |
Please send me your email address.
Thanks Ali |
Reynolds stress transport model with elliptic relaxation | xiao | OpenFOAM Running, Solving & CFD | 1 | February 15, 2020 12:06 |
RSM: Reynolds Stress Model | ebtedaei | Main CFD Forum | 0 | October 31, 2016 12:33 |
Use of Reynolds Stress Model (7 equations) in micro-combustion | S Pradip | FLUENT | 2 | May 11, 2016 01:39 |
Reynolds Stress Model | deeimproptus | FLUENT | 3 | November 3, 2011 03:23 |
Blow up of reynolds stress turbulence model | newbee | OpenFOAM Running, Solving & CFD | 4 | August 12, 2010 05:10 |
