Problem: LES results start to diverge after 10 flow-through time |
November 26, 2019, 05:49 |
Jin Zhang
Rep Power: 7 |
Dear Foamers,
I have a quite weird problem when I run the incompressible LES for airfoil with roughness elements in Openfoam. I monitored cl and cd, and the results went well before 10 flow-through time and it seems that it is almost converged and I planned to do time averaging. However, it started to diverge after 10 flow-through time. Is that the wrong boundary condition definitions? Attached are the nut and p contours and it seems that it started diverging from bottom boundary. this is my boundary condition definition: inlet: U(fixedValue), p(ZG), nut(calculated) outlet: U(ZG), p(fixedValue 0), nut(ZG) top&bottom: U(ZG), p(ZG), nut(ZG) Are the boundary conditions defined correctly? Or is there any other problems which might caused divergence? ezgif.com-video-to-gif.gif ezgif.com-video-to-gif (1).gif Best regards, Jin |
boundary conditions, divergence, les |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
LES of highly heated pipe flow - incorrect results | MichalH | FLUENT | 3 | June 3, 2009 05:00 |
