Turbine simulation and turbulence parameters: Floating point exception issues
Old   November 30, 2016, 08:31
Default Turbine simulation and turbulence parameters: Floating point exception issues
Dave
DaveR is on a distinguished road
Hi all,
I have been trying to validate my OpenFOAM methodology by modelling a 3-bladed water turbine and validating it against literature as found here.
Ultimately I want to match recorded torque values over the blades through refinement of the boundary layer region, however at the moment I am just trying to get a simulation running.
I have spent a long time trying to obtain a semi-reasonable mesh to solve using pimpleDynamicMeshFoam. I feel like my current mesh is good enough to get atleast something out. I've attached a screenshot and welcome your thoughts on this.
I am solving using the k-omegaSST turbulence model, however I am little confused about the calculation of input parameters in the 0 folder.
I have calculated the input variables nut, k, omega using the turbulence guidelines found here, and verified them through the calculator here. Velocity is taken from the aforementioned literature, p is set as zeroGradient.
My simulation currently fails through the Courant number exploding, resulting in a floating point exception early in the simulation. Given that the Courant number is governed by u*t/x, in which freestream velocity and time step are stated in literature - this would initially lead me to believe the mesh is still the issue.
However, Para View doesn't seem to offer any hints as to a location in the mesh that could be failing, so perhaps this is likely to result from my boundary conditions/input parameters?
Is anyone able to shed any light on my thought processes on setting up the simulation correctly using turbulence models, or perhaps where else I may be going wrong?
I've attached my case at the following google drive link if anyone could be so kind to take a look and offer any advice on getting this running and heading towards validation - it's been troubling me for some time now!
https://drive.google.com/open?id=0B3...UJxc1BpTS1XZDQ
Best regards,
Dave
DaveR is offline   Reply With Quote
Old   November 30, 2016, 10:57
Dave
For ease of reference my simulation criteria have been calculated as follows:
Literature values:
Turbulence model: kOmegaSST
U = 2.8 m/s
Tip speed ratio = 2
Turbulent Intensity, I = 2%
Chord Length = 0.032 m
Time step = 1 rot deg/time step = 2.707e-04 s
Calculated values:
p = constant
Turbulent Viscosity, nut = 2.4e-03
Turbulent Energy, k = 4.704e-03
Specific Dissipation Rate, omega = 1.9595
Turbulent Length Scale = ~5% of inlet height = 0.035
Angular velocity, omega = 64 rad/s
Anything particularly obvious that could be wrong?
Old   November 30, 2016, 12:26
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Dave,
I have done similar simulations before and found some good case files that they might be helpful in terms of the setup etc. One of the cases works fine on OpenFoam v 2.3.2. The other case file requires some work to get it to work. Anyway, the file are uploaded in mediafire;
HTML Code:
http://www.mediafire.com/file/4mia94y679r645d/OpenFOAM-2D-VAWT-master.zip
HTML Code:
http://www.mediafire.com/file/n8sjaavaapcqvay/Naca-TSR1.0.zip
Please let me know if you find them helpful.
Best,
tareqkh is offline   Reply With Quote
Old   December 1, 2016, 04:30
Dave
Hi Khamlaj,
Thanks very much for those, I'll look over them today and report back any findings!
All the best,
Dave
Old   December 1, 2016, 11:19
Dave
Hi again Khamlaj,
The second mesh seems to be faulty as it doesn't load in ParaView, detailing the error:
--> FOAM FATAL ERROR:
Symmetry plane 'symmetryPatches' is not planar.
At local face at (-8.82 -9 0.005) the normal (0 -1 0) differs from the average normal (0 0 0) by 1
Either split the patch into planar parts or use the symmetry patch type
From function virtual void Foam::symmetryPlanePolyPatch::calcGeometry(Foam::P streamBuffers&)
in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64.
FOAM exiting
The first mesh seems to solve well, although not at the time step stated in the control dictionary. I've modified this case to run on my own polyMesh files and the simulation quickly fails with the Courant number exploding.
Do you think this is then indicative of a mesh problem, rather than the initial conditions listed in my 0 directory?
I have also wondered if simulation failure is related to the fvSchemes and fvSolutions dictionary.. What are your thoughts on this? I don't feel I understand these dictionaries very well - perhaps this could be the root of the problem?
Thanks again for your time,
Dave
Facing a floating point error when reducing time step in a unsteady simulation withwolf STAR-CCM+ 7 November 14, 2018 19:38
Floating point exception (yes...) sandri_92 OpenFOAM Running, Solving & CFD 0 October 23, 2016 14:42
rhoCentralFoam - kOmegaSST - Floating point exception DGW OpenFOAM Running, Solving & CFD 1 September 1, 2016 07:45
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 18:23
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
