Thermocapillary free surface flow
Old   April 7, 2009, 06:08
Smile Thermocapillary free surface flow
Zaki Saldi
zakifoam is on a distinguished road
Dear all,
I am interested in the VOF simulation of free surface flow driven by surface tension gradient due to surface temperature variation.
To do this, I have tried to add energy equation (temperature-based) in interFoam, in which the thermal conductivity is weighted by volume fraction, just like density and viscosity.
Additionally, at the interface, the smeared surface force has the normal and tangential components of the following form:
where
Here sigma_0 is surfac tension at reference temperature, sigma_T is dsigma/dT, i.e. the temperature gradient of surface tension, and T_0 is the reference temperature.
The first term of the normal force already exists in interFoam, so I need to implement the second term of the surface force and the tangential force.
I ended up with the following in UEqn.H :
surfaceScalarField muf = twoPhaseProperties.muf();
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
- fvm::laplacian(muf, U)
- (fvc::grad(U) & fvc::grad(muf))
//- fvc::div(muf*(fvc::interpolate(dev(fvc::grad(U))) & mesh.Sf()))
if (momentumPredictor)
solve
UEqn
fvc::reconstruct
fvc::interpolate(interface.sigmaK())*fvc::snGrad(g amma)
+ fvc::interpolate(dsigmadT*(T-T0)*interface.K())*fvc::snGrad(gamma)
+ fst
- ghf*fvc::snGrad(rho)
- fvc::snGrad(pd)
) * mesh.magSf()
and in pEqn.H :
phi = phiU +
+ fst
)*rUAf*mesh.magSf();
Here, I have implemented the second term for the normal force (highlighted in blue), but not the whole tangential component of the surface force (in red).
This tangential part is a bit confusing, since in UEqn.H, everything in fvc::reconstruct brackets should be of the type surfaceScalarField. I tried to specify fst as follows:
volVectorField nhat = gradGamma/(mag(gradGamma) + deltaN);
volVectorField fst = dsigmadT*(fvc::grad(T) - nhat*(nhat & fvc::grad(T)))*mag(gradGamma);
Here, fst is a volVectorField, which can not be used in UEqn.H and pEqn.H above.
Could anyone help me with this problem?
Thanks a lot,
Zaki
zakifoam is offline   Reply With Quote
Old   May 7, 2009, 04:30
Hamed Aghajani
haghajani is on a distinguished road
Dear Zaki,
Have you had any success in solving your problem?
please let me know,
Best,
Hamed
haghajani is offline   Reply With Quote
Old   May 19, 2009, 07:29
Zaki Saldi
Hi Hamed,
I think I have moved one very small step forward in solving the problem with the tangential force. Now I have a modified interFoam to account for this thermocapillary effect. However, after testing the code, I was not satisfied with the result in comparison with the one in literature.
Please find the source code and the test case in the attachment. The test case is thermocapillary motion of deformable drops in a vertical temperature gradient (no gravity), which follows the one reported in:
www.stanford.edu/group/ctr/Summer/SP08/3_2_Lopez.pdf
I tested the first problem in that paper (case of limit of zero marangoni number, page 161-162), and comparing my result with figure 1 (page 162).
Please kindly have a look at it and I would appreciate it if you could give comments, suggestions, help.
regards,
zaki
Old   May 19, 2009, 11:17
Default adding Temprature to les/interfoam
Hamed Aghajani
Dear Zaki,
Thanks for updating the thread,
I want to add temperature to les/interFoam?
The equation I am trying to add is;
(1)
rho*Cp*[ddt(gamma*T)+grad(gamma*U*T)]=laplacian(gamma*Landa_eff*T)
I know that, a surfaceScalarField should be exist to update thermal conductivity in each time step
(2)
{Landa_eff = Landa + Cp*nuSgs()}, I have Les Turbulence Model as well.
To comply the Eq.2, should I modify a new library for Landa(Thermal conductivity), to call it in TEqn as twoPhaseProperties.landa(), or something else. I also tried with Creatfield and it didn't worked.
Please elaborate,
Kindly,
Hamed
hamed.aghajani@gmail.com
h.aghajani@kingston.ac.uk
Old   May 19, 2009, 12:01
Zaki Saldi
Hi Hamed,
My questions & remarks:
1. Why do you need gamma in the energy equation (eq. 1) ?
2. Seems to me the terms in eq 2 are dimensionally inconsistent. I think they should be like this:
suppose landa = thermal conductivity, and alpha thermal diffusivity.
so alpha = landa/(rho*Cp)
landa_eff = landa + landa_sgs = landa + rho*Cp*alpha_sgs = landa + rho*Cp*nu_sgs / Pr_t
where Pr_t is the turbulent Prandtl number.
It is of course elegant to define landa (or its cell-face value landaf) in a new library. But I think you can also do it like this:
- define landa as volScalarField, also constants landa1 & landa2 for each fluid
- after calculating gamma, define landa = landa1*gamma + landa2*(1-gamma), also similarly with Cp
- before solving energy equation:
surfaceScalarField gammaf = fvc::interpolate(gamma);
surfaceScalarField landaf = fvc::interpolate(landa);
surfaceScalarField landaEff
"landaEff",
landaf
+ fvc::interpolate(rho*Cp*turbulence->nuSgs()/Pr_t)
kind regards,
zaki
Old   May 20, 2009, 13:23
Default added TEqn to les/interfoam
Hamed Aghajani
Dear Zaki,
Thanks for your kind reply,
I saw the eq.(1) in a paper, Cryogenics 48 (2008) 238–247, and have not understood why the autors chose the energy equation in that form. But I attached part of that paper to this thread. you can find it in eq.8;
I couldn't call turbulent Prandt number and the TEqn, as you suggested,I wrote is;
surfaceScalarField landaf = fvc::interpolate (landa);
"landaEff"
landaf
+ fvc::interpolate(rho*Cp*turbulence->nuSgs())
fvScalarMatrix TEqn
rho*Cp*
(fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(landaEff, T)
TEqn.solve();
It is running on a case and I haven't checked the result yet,
Kindly,
Hamed
Old   August 24, 2014, 03:24
Unhappy thermocapillary
FoEbrahimi is on a distinguished road
how can i coding thermocapillary flows in a confined microchannel
with LBM method?
FoEbrahimi is offline   Reply With Quote
Old   December 9, 2016, 20:22
Kalpana Hanthanan Arachchilage
kal1943335 is on a distinguished road
Dear Dr. Zaki,
I've referred to your PhD dissertation as I'm planning to implement and validate the tangential component of the surface tension force. I've tried to simulate the cavity simulation you used to validate surface tension force. However, i'm not getting the correct result. One thing i noticed is they provided data to obtain the physical properties of liquid. but, it didn't mention anything about the vapor side physical properties. Can you please let me know, what kind of physical properties you used for vapor side.
Thank you,
kal1943335 is offline   Reply With Quote
Old   December 12, 2016, 04:59
Ricky
kera is on a distinguished road
Originally Posted by kal1943335 View Post
Dear Dr. Zaki,
Thank you,
Hello Kalpana,
If I am not wrong, are you trying to validate your case in two-phase environment compared to Dr. Saldi's single-phase? If yes, then there are 2 more test cases you could actually use to validate your tangential component of the surface tension force.
1) Is already mentioned here (see post -> #3)
2) you could also validate your case with his "Two-Phase Marangoni driven flows" (sec 3.5 of his thesis) --> which I am trying to do currently but the results are way off. In my case the surface height at left wall is 0.194 and at the right wall is 0.204.
Perhaps you may come up with some better solution.
Regards,
Ricky
kera is offline   Reply With Quote
Old   December 12, 2016, 10:20
Originally Posted by kera View Post
Hello Kalpana,
Regards,
Ricky
Dear Ricky,
Thank you for your reply. Actually i was referring to section 3.5. As these non-dimensional numbers are only based on liquid properties, you have no idea what kind of properties you should use to the vapor side. I'm using interfoam based solver and i'm also getting similar results that you obtained. However, I assumed liquid and vapor properties to be equal. but, when i used different properties for vapor solution changes and I'm wondering what kind of property i have to use. The other thing is spurious currents.
I have tried the droplet simulation as well, but those curved surfaces increase spurious currents and over predicting the results.
there is another test case you can simulate. these are the references for that.
N.Balcazar et al/ International journal of heat and fluid flow (2016)
H.Liu et al/ Journal of computational physics 231 (2012) 4433-4453
Will let you know if there is any improvement. And please let me know what are the vapor properties you used for the above simulation.
Regards,
Kalpana
Old   December 12, 2016, 11:44
Ricky
Hello Kalpana,
Well I am using interfoam for the time being.
Initially I assumed both the fluids have same properties, I had a solution which was no way to be considered and then I assumed second fluid as air, I had another solution but it's kinda miss leading as the surface height on the left and right walls goes upto 0.182 and 0.216 or something like that.
Regards,
Ricky
free surface, interfoam, marangoni, thermocapillary
free surface flow past cylinder vineet FLUENT 1 February 21, 2011 23:11
free surface flow in non-inertial reference frame Tiedingg FLOW-3D 1 February 26, 2009 19:51
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Analytical Solution for a Free Surface Flow Ferreira, VG Main CFD Forum 0 February 25, 2007 04:56
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
